    Need help : Code to reload mutiple component
    5 Posts 2 Posters 194 Views 2 Watching
    • Q Offline
      QUOCANH ELNINO
      Hello, can anyone help me resolve this isssue :
      • I have many simple component in with name : com1, com2, com3...in a file original.
      • I have save all component to file com1.skp, com2.skp, com3.skp... in folder A
      • Then i edit file component com1.skp, com2.skp, com3.skp....in folder A, Now i want to reload all component from folder A (have edited) to file original.
      • It's same action with reload component in sketchup but with mutiple block in one time.
        Thanks for any help guy!
        Look at this...
        https://sketchucation.com/forums/viewtopic.php?p=331966#p331966
        • Q Offline
          QUOCANH ELNINO
          @tig said:
          Look at this...
          @tig said:
          Look at this...
          Thanks TIG, But when I import all component in folder A to file, all new component imported turn to Com1#1, Com 2#,...And old component in file not change πŸ˜•
            So what you need is to load Com1, then if Com1 exists take Com1#1 and add an instance of it into the model using Com1 instance's transformation. Then remove the original Com1 definition, then rename Com1#1 as Com1...
            This is doable but somewhat convoluted !
            I'll look at a snippet...
              Try this...
              module TIG
                module DefinitionReplacer
                  def self.run()
                    model=Sketchup.active_model
                    defns=model.definitions
                    model.start_operation("DefinitionReplacer", true)
                    counter=0
                    defns.to_a.each{|defn|
                      name=defn.name
                      next if name=~/[#]/
                      defns.to_a.each{|d|
                        n=d.name
                        next unless n=~/[#]/
                        next unless d.instances[0]
                        next unless n.split("#")[0]==name
                        defn.name=name+rand.to_s
                        d.name=name
                        ins=d.instances
                        defn.instances.each{|i|
                          i.definition=d
                        ins.each{|i|
                          i.erase!
                        counter+=1
                      defns.remove(defn)
                    model.commit_operation
                    puts "Processed #{counter} definitions"
                  end#def
                end #module
              end #module
              TIG;;DefinitionReplacer.run()
              #to use, it assumes you have a number of component definitions [Com1, Com2, etc],
              #and you have already imported a similar set of edited ones into the model [Com1#1, Com2#1 etc].
              #to run it, paste all of this into the Ruby Console, it should auto-run.
              #all instances of the original Com1 become Com1#1, renamed as Com1,
              #any instances of the previous Com1#1 are erased and its definition removed.
              #it's one step undo-able
