    How to curt hole in log wall
    28 Posts 4 Posters 1.1k Views 4 Watching
    • N Offline
      numerobis
      @ntxdave said:
      Thanks for the link. That plugin is not available via the Sketchucatiob Plugin store.
      Releases · Eneroth3/eneroth-solid-tools
      Solid operations for SketchUp. Contribute to Eneroth3/eneroth-solid-tools development by creating an account on GitHub.
      GitHub (github.com)
      • BoxB Offline
        @box said:
        That Icon is Delete from the 'Standard' toolbar.
        @ntxdave said:
        Thanks for the link but I could not find a toolbar that had the delete icon.
        • ntxdaveN Offline
          ntxdave
          Thanks Box, I will have a look.
          BTW, is there a way to add the bottom view to a toolbar?
          Press F1...thank me later
          • BoxB Offline
            Not in the older versions, but you can make a keyboard shortcut.
            • ntxdaveN Offline
              ntxdave
              Again, thank you very much. I make a new small toolbar that has the Erase, Undo, Redo and Model Info icons. I wanted to place it along the side bar. I also tried to set it do double wide but it would not allow me to do it in that position. Am I missing something?
              I will also add a shortcut for the Bottom view. 😄
              • BoxB Offline
                No you aren't missing something, the toolbar won't do double wide when docked, even though the Large Toolset does. It has been a complaint for many years. And you can't put the large toolset across the top.
                Far be it for us to question the design gods of the UI, they obviously know something we don't.
                • ntxdaveN Offline
                  ntxdave
                  Added.........Alt+Shift+B
                  Again, many thanks. I had a bad day on the SketchUp forum so this was something very positive. 😄
                  • ntxdaveN Offline
                    ntxdave
                    Box, thanks to your advice/info I was able to modify the Large Toolbar and add some functions (including the erase tool). Here is what I now have in the top section of the Large Toolbar.
                    Also downloaded the Eneroth Solid Tools plugin for dealing with cutting window and door wholes in my log cabin walls. Like it better than the standard tools (for this situation).
                    Again, thanks for your feedback and assistance. 👍
                    • 2 / 2
