    How to curt hole in log wall
    28 Posts 4 Posters 2.1k Views 4 Watching
    • BoxB Offline
      It's worth noting that this Trim function is broken in 2023, you have to reselect the tool each time.
      But I suspect you aren't working with 2023 anyway.
      • ntxdaveN Offline
        ntxdave
        You are right. I am using 2020. πŸ‘
        Press F1...thank me later
        • Gus RG Offline
          Gus R
          Don't worry. I was stumped with the subtract tool at first since I was using Bool Tools for a long time.
          www.instagram.com/gusrobatto/
          www.facebook.com/gusrobatto
          • ntxdaveN Offline
            ntxdave
            Box, what is the tool on your toolbar next to the eraser (the one you clicked on to delete the object you used for the trim and subtract functions)?
            I was going to try to modify my main toolbar to include that tool but I cannot seem to get to the option to modify a toolbar. I cannot get the ability to edit a toolbar to show up.
            BTW: I tried both of the options that you showed in your videos and got them both to work. πŸ‘ πŸ‘ πŸ‘ πŸ‘
            • BoxB Offline
              That Icon is Delete from the 'Standard' toolbar.
              This thread has a gif showing how to make a custom toolbar from about 9 years ago.
              https://sketchucation.com/forums/viewtopic.php?f=15&t=59701&hilit=+toolbar#p543863
              • N Offline
                numerobis
                You could also use Eneroth Solid Tools which support preselection of multiple objects...
                SketchUp Extension Warehouse
                Your library of custom third-party extensions created to optimize your SketchUp workflow.
                (extensions.sketchup.com)
                • ntxdaveN Offline
                  ntxdave
                  Thanks for the link but I could not find a toolbar that had the delete icon.
                  Thanks for the link. That plugin is not available via the Sketchucatiob Plugin store.
                  • Gus RG Offline
                    Gus R
                    Thanks Box. I finally expanded my use of Sketchup's solid tools. Got stuck in a routine.
                    • N Offline
                      numerobis
                      Releases Β· Eneroth3/eneroth-solid-tools
                      Solid operations for SketchUp. Contribute to Eneroth3/eneroth-solid-tools development by creating an account on GitHub.
                      GitHub (github.com)
                      • BoxB Offline
                        • ntxdaveN Offline
                          ntxdave
                          Thanks Box, I will have a look.
                          BTW, is there a way to add the bottom view to a toolbar?
                          • BoxB Offline
                            Not in the older versions, but you can make a keyboard shortcut.
                            • ntxdaveN Offline
                              ntxdave
                              Again, thank you very much. I make a new small toolbar that has the Erase, Undo, Redo and Model Info icons. I wanted to place it along the side bar. I also tried to set it do double wide but it would not allow me to do it in that position. Am I missing something?
                              I will also add a shortcut for the Bottom view. πŸ˜„
                              • BoxB Offline
                                No you aren't missing something, the toolbar won't do double wide when docked, even though the Large Toolset does. It has been a complaint for many years. And you can't put the large toolset across the top.
                                Far be it for us to question the design gods of the UI, they obviously know something we don't.
                                • ntxdaveN Offline
                                  ntxdave
                                  Added.........Alt+Shift+B
                                  Again, many thanks. I had a bad day on the SketchUp forum so this was something very positive. πŸ˜„
                                  • ntxdaveN Offline
                                    ntxdave
                                    Box, thanks to your advice/info I was able to modify the Large Toolbar and add some functions (including the erase tool). Here is what I now have in the top section of the Large Toolbar.
                                    Also downloaded the Eneroth Solid Tools plugin for dealing with cutting window and door wholes in my log cabin walls. Like it better than the standard tools (for this situation).
                                    Again, thanks for your feedback and assistance. πŸ‘
                                    • 2 / 2
