    How to curt hole in log wall
    28 Posts 4 Posters 1.1k Views 4 Watching
    • N Offline
      numerobis
      You could also use Eneroth Solid Tools which support preselection of multiple objects...
      SketchUp Extension Warehouse
      Your library of custom third-party extensions created to optimize your SketchUp workflow.
      (extensions.sketchup.com)
      • ntxdaveN Offline
        ntxdave
        @box said:
        That Icon is Delete from the 'Standard' toolbar.
        This thread has a gif showing how to make a custom toolbar from about 9 years ago.
        https://sketchucation.com/forums/viewtopic.php?f=15&t=59701&hilit=+toolbar#p543863
        Thanks for the link but I could not find a toolbar that had the delete icon.
        Thanks for the link. That plugin is not available via the Sketchucatiob Plugin store.
        Press F1...thank me later
        • Gus RG Offline
          Gus R
          Thanks Box. I finally expanded my use of Sketchup's solid tools. Got stuck in a routine.
          www.instagram.com/gusrobatto/
          www.facebook.com/gusrobatto
          • N Offline
            numerobis
            Releases Β· Eneroth3/eneroth-solid-tools
            Solid operations for SketchUp. Contribute to Eneroth3/eneroth-solid-tools development by creating an account on GitHub.
            GitHub (github.com)
            • BoxB Offline
              • ntxdaveN Offline
                ntxdave
                Thanks Box, I will have a look.
                BTW, is there a way to add the bottom view to a toolbar?
                • BoxB Offline
                  Not in the older versions, but you can make a keyboard shortcut.
                  • ntxdaveN Offline
                    ntxdave
                    Again, thank you very much. I make a new small toolbar that has the Erase, Undo, Redo and Model Info icons. I wanted to place it along the side bar. I also tried to set it do double wide but it would not allow me to do it in that position. Am I missing something?
                    I will also add a shortcut for the Bottom view. πŸ˜„
                    • BoxB Offline
                      No you aren't missing something, the toolbar won't do double wide when docked, even though the Large Toolset does. It has been a complaint for many years. And you can't put the large toolset across the top.
                      Far be it for us to question the design gods of the UI, they obviously know something we don't.
                      • ntxdaveN Offline
                        ntxdave
                        Added.........Alt+Shift+B
                        Again, many thanks. I had a bad day on the SketchUp forum so this was something very positive. πŸ˜„
                        • ntxdaveN Offline
                          ntxdave
                          Box, thanks to your advice/info I was able to modify the Large Toolbar and add some functions (including the erase tool). Here is what I now have in the top section of the Large Toolbar.
                          Also downloaded the Eneroth Solid Tools plugin for dealing with cutting window and door wholes in my log cabin walls. Like it better than the standard tools (for this situation).
                          Again, thanks for your feedback and assistance. πŸ‘
                          • 2 / 2
