    Can't Install Extrude Tools on SKP 2022
    2 Posts 2 Posters 271 Views 2 Watching
    • R
      RoCas777
      I tried installing extrude tools by TIG, first I did it through the Sketchucation Extension Store, the installation was aparently succesful, but the tools didn't show up, even restarting the program several times, then i downloaded the rbz file and tried to install directly from it, but it gives me the following error: ERROR INSTALLING EXTRUDE TOOLS.RBZ
      Has anyone have ran in the same problem, is there a way to fix this?? really want to use this plugin :C
      • TIGT
        The Extrude Tools install and work just fine in all current versions of SketchUp.
        So something is clearly wrong with your end...
        Have you installed SketchUp properly ?
        If you are using a MAC have you installed SketchUp properly - i.e. you NOT working from the installer app version...
        But if you are on a PC Repair the installation whilst using Run as administrator on the Downloaded installer's exe file...
        If all else fails, try this clunky work around...
        Change the file-type suffix of the downloaded .RBZ to .ZIP
        Now extract the contents to a folder and move the RB and subfolder of the same name [with its contents in tact] into your v2022 Plugins folder.
        If it doesn't extract properly try downloading the RBZ another way...
        After you get the RB & subfolder into Plugins restart SketchUp and see what happens...
