    Group from slice in Ruby
    5 Posts 3 Posters 1.1k Views 3 Watching
    • SminkyS
      Sminky
      I believe there is no way of creating a group from the slice obtained by section from Ruby but this would be a great function to have for automating several processes.
      First: am I correct? Is there really no way of doing this?
      Second: if I am correct, would it be possible to implement this?
      Thank you for your time and best regards
      • TIGT
        Look in the PluginStore for 'SectionCutFace'...
        • Dan RathbunD
          Dan Rathbun
          I logged this as an API Feature Request back in JAN 2019 ...
          Create Group from Slice (Section Plane) · Issue #189 · SketchUp/api-issue-tracker
          SketchUp Ruby API Feature Request Please expose the internal method from the section plane right-click context menu, to create "Create Group from Slice". (Repeatedly asked for in the forums over the years. Currently hacky platform depend...
          GitHub (github.com)
          Also a request to export a slice from Ruby ...
          Sketchup::SectionPlane#export_slice · Issue #406 · SketchUp/api-issue-tracker
          API Feature Request Please implement an API method to expose the native GUI feature via File > Export > Section Slice... And allow any section plane to be exported. (The GUI command seems to only become enabled when a top level section p...
          GitHub (github.com)
          I'm not here much anymore.
          • SminkyS
            Sminky
            Thank you for the proposal but I would like to use this from ruby, not in the UI.
            I downloaded the plugin anyway hoping it would contain code that would let me understand how it can be done but it's scrambled.
            Best regards
            • SminkyS
              Sminky
              Any news on this?
              Best regards
