    Plugin "CD STANDARD" some tools not working
    3 Posts 2 Posters 232 Views 2 Watching
    • atelierpaarA Offline
      atelierpaar
      Hello,
      I like to work with the toolset "CD STANDARD" since many years
      After installing SU 2023 some tools won´t work anymore.
      In the following I copied the non working commands from "cd_standard.rb"
      Can somebody help to get these tools working again??
      Uli
      "Undo"
      #cmd = UI::Command.new("Undo") { Sketchup.send_action 57643 }
      #cmd.small_icon = "CD_ICONS/STANDARD/editundo_sm.png"
      #cmd.large_icon = "CD_ICONS/STANDARD/editundo_lg.png"
      #cmd.tooltip = "Undo"
      #cmd.status_bar_text = "Undo"
      #cmd.menu_text = "Undo"
      #gp_cd_standard_tb.add_item(cmd)
      ("Redo")
      #cmd = UI::Command.new("Redo") { Sketchup.send_action 57644 }
      #cmd.small_icon = "CD_ICONS/STANDARD/editredo_sm.png"
      #cmd.large_icon = "CD_ICONS/STANDARD/editredo_lg.png"
      #cmd.tooltip = "Redo"
      #cmd.status_bar_text = "Redo"
      #cmd.menu_text = "Redo"
      ("XRay")
      cmd = UI::Command.new("XRay") { Sketchup.send_action 10596 }
      cmd.small_icon = "CD_ICONS/STANDARD/toggleXray_sm.png"
      cmd.large_icon = "CD_ICONS/STANDARD/toggleXray_lg.png"
      cmd.tooltip = "Xray"
      cmd.status_bar_text = "Xray"
      cmd.menu_text = "Xray"
      ("WireFrame")
      cmd = UI::Command.new("WireFrame") { Sketchup.send_action 10597 }
      cmd.small_icon = "CD_ICONS/STANDARD/renderwireframe_sm.png"
      cmd.large_icon = "CD_ICONS/STANDARD/renderwireframe_lg.png"
      cmd.tooltip = "Wireframe"
      cmd.status_bar_text = "Wireframe"
      cmd.menu_text = "Wireframe"
      ("HiddenLine")
      cmd = UI::Command.new("HiddenLine") { Sketchup.send_action 10598 }
      cmd.small_icon = "CD_ICONS/STANDARD/renderhiddenline_sm.png"
      cmd.large_icon = "CD_ICONS/STANDARD/renderhiddenline_lg.png"
      cmd.tooltip = "Hidden Line"
      cmd.status_bar_text = "Hidden Line"
      cmd.menu_text = "Hidden Line"
      ("Shaded")
      cmd = UI::Command.new("Shaded") { Sketchup.send_action 10599 }
      cmd.small_icon = "CD_ICONS/STANDARD/rendershaded_sm.png"
      cmd.large_icon = "CD_ICONS/STANDARD/rendershaded_lg.png"
      cmd.tooltip = "Shaded"
      cmd.status_bar_text = "Shaded"
      cmd.menu_text = "Shaded"
      ("Textured")
      cmd = UI::Command.new("Textured") { Sketchup.send_action 10600 }
      cmd.small_icon = "CD_ICONS/STANDARD/rendertextured_sm.png"
      cmd.large_icon = "CD_ICONS/STANDARD/rendertextured_lg.png"
      cmd.tooltip = "Textured"
      cmd.status_bar_text = "Textured"
      cmd.menu_text = "Textured"
      ("Monochrome")
      cmd = UI::Command.new("Monochrome") { Sketchup.send_action 10601 }
      cmd.small_icon = "CD_ICONS/STANDARD/rendermonochrome_sm.png"
      cmd.large_icon = "CD_ICONS/STANDARD/rendermonochrome_lg.png"
      cmd.tooltip = "Monochrome"
      cmd.status_bar_text = "Monochrome"
      cmd.menu_text = "Monochrome"
      ("Display Edges")
      #cmd = UI::Command.new("Display Edges") {
      if Sketchup.active_model.rendering_options["EdgeDisplayMode"] == 0
      Sketchup.active_model.rendering_options["EdgeDisplayMode"] = 1
      else
      Sketchup.active_model.rendering_options["EdgeDisplayMode"] = 0
      #cmd.large_icon = "CD_ICONS/STANDARD/toggleedges_lg.png"
      #cmd.small_icon = "CD_ICONS/STANDARD/toggleedges_sm.png"
      #cmd.tooltip = "Display Edges"
      #cmd.status_bar_text = "Display Edges"
      #def edges_validation_proc
      return MF_CHECKED
      else
      return MF_UNCHECKED
      #end
      #cmd.set_validation_proc { edges_validation_proc }
      ("Edge Color Mode")
      cmd = UI::Command.new("Edge Color Mode") do
      ro = Sketchup.active_model.rendering_options
      ecm = ro["EdgeColorMode"]
      ecm = ((ecm + 1) % 3)
      ro["EdgeColorMode"] = ecm
      Sketchup.set_status_text "Egde Color Mode: " + ["by Material", "All Same", "by Axis"][ecm]
      #end
      #cmd.large_icon = "CD_ICONS/STANDARD/edgeColorMode_lg.png"
      #cmd.small_icon = "CD_ICONS/STANDARD/edgeColorMode_sm.png"
      #cmd.tooltip = "Cycle Edge Color Mode"
      #cmd.status_bar_text = "Cycle Edge Color"
      ("Profiles")
      cmd = UI::Command.new("Profiles") { Sketchup.send_action 10603 }
      cmd.large_icon = "CD_ICONS/STANDARD/toggleprofiles_lg.png"
      cmd.small_icon = "CD_ICONS/STANDARD/toggleprofiles_sm.png"
      cmd.tooltip = "Display Profiles"
      cmd.status_bar_text = "Display Profiles"
      def profiles_validation_proc
      if Sketchup.active_model.rendering_options["DrawSilhouettes"] == true
      return MF_CHECKED
      else
      return MF_UNCHECKED
      cmd.set_validation_proc { profiles_validation_proc }
      ("Edge Color: Axis")
      cmd = UI::Command.new("Edge Color: Axis") do
      if ecm != 2
      ecm = 2
      Sketchup.set_status_text "Egde Color Mode: by Axis"
      else
      ecm = 1
      Sketchup.set_status_text "Egde Color Mode: Default"
      cmd.large_icon = "CD_ICONS/STANDARD/toggleAxisEdge_lg.png"
      cmd.small_icon = "CD_ICONS/STANDARD/toggleAxisEdge_sm.png"
      cmd.tooltip = "Edge Color by Axis"
      def axisedge_validation_proc
      if Sketchup.active_model.rendering_options["EdgeColorMode"] == 2
      return MF_CHECKED
      else
      return MF_UNCHECKED
      cmd.set_validation_proc { axisedge_validation_proc }
      ("Shadows")
      cmd = UI::Command.new("Shadows") { Sketchup.send_action 10602 }
      cmd.small_icon = "CD_ICONS/STANDARD/toggleshadows_sm.png"
      cmd.large_icon = "CD_ICONS/STANDARD/toggleshadows_lg.png"
      cmd.tooltip = cmd.status_bar_text = "Display Shadows"
      def shadow_validation_proc
      if Sketchup.active_model.shadow_info["DisplayShadows"] == true
      return MF_CHECKED
      else
      return MF_UNCHECKED
      cmd.set_validation_proc { shadow_validation_proc }
      ("Display Shadow Settings")
      cmd = UI::Command.new("Display Shadow Settings") { Sketchup.send_action 10533 }
      cmd.large_icon = "CD_ICONS/STANDARD/shadowsettings_LG.png"
      cmd.small_icon = "CD_ICONS/STANDARD/shadowsettings_SM.png"
      cmd.tooltip = cmd.status_bar_text = "Display Shadow Settings Dialog Box"
        All of the menu items that start with a # are disabled and won't even load.
        The send_action ones using a number only work on PC, but the undocumented ones seem to have been deprecated since v2021
        There are 'text' alternatives that still work - e.g. Wireframe mode can be called by using
        Sketchup.send_action('renderWireFrame:') instead of Sketchup.send_action 10597
        Here's the full API list...
        https://ruby.sketchup.com/Sketchup.html#send_action-class_method
        I can't see an equivalent for Xray mode...
          atelierpaar
          Hi Tig,
          thanks for your great help
          got almost everything to work again.
          "Sketchup.send_action 10513" works just fine
          one command resists :
          Old
          cmd = UI::Command.new("Layers") { Sketchup.send_action 21354 }
          cmd.large_icon = "CD_ICONS/STANDARD/layers_lg.png"
          cmd.small_icon = "CD_ICONS/STANDARD/layers_sm.png"
          cmd.tooltip = cmd.status_bar_text = "Show Layers Palette"
          New
          cmd = UI::Command.new("Layers") { Sketchup.send_action 21032 }
          thanks again -
          Uli
