    Releasing/Removing Extension Licences
    3 Posts 2 Posters 228 Views 2 Watching
    • P Offline
      pipinek
      Greetings,
      How to remove all installed via SketchUcation and Extension Warehouse, manually installed, extention licences?
      I have to migrate all of them to a new machine. I have no additional licences (3 per user) ones available.
      Thank you in advance.
        You need to do Extension Warehouse licensing through SketchUp.
        But for SketchUcation Licensing you can manage [release/activate] your licenses with the dialog that opens from the MyLicenses item in the Extensions > SketchUcation submenu
        You need the latest version of SketchUcation tools and the extensions/libs etc installing beforehand and restart SketchUp to sync thing, before trying to do any license management.
        • P Offline
          pipinek
          Splendid, thank you very much TIG.
          In this case there is a huge advantage, I see using SketchUcation resources over Extension Warehouse.
          I thought only a few extensions could be unlicencing via Sketchucation Tool as suggested.
          Once more many thanks TIG
