    LordOfTheToolbars /SUp 2023
    4 Posts 3 Posters 293 Views 3 Watching
      Julien 2
      Setting up Sketchup 2023 and found important missing Vignette in LOTT.
      The 3rd vignette [Full Screen] missing, I use it almost every day.
      I compared Default Parameters from SU22 and SU23 and found two (2) lines missing in Plugin Configuration
      Toolbar name in SU23 missing.
      #16, Toggle CleanScreen mode
      #17, CleanScreen configuration
      LOTT Version in both app. is V2.4a
      Lib F6 Versions are different
      SU22 Lib F6 is 13.6a
      SU23 Lib F6 is 13.9a
      if is this the case, Should I just keep on using SU22 and drop SU23?
      Merci ..
        See Fredo6's remarks in the LOTT thread: https://sketchucation.com/forums/viewtopic.php?f=323&t=73776&start=270#p688246
        • E Offline
          expandball Newcomers
          I think yes.
          • E Offline
            Does it have anything to do with this issue?
