    Fredo 6 not working
    3 Posts 2 Posters 164 Views 2 Watching
    • W
      wohguandot
      I'm trying to use JointPushPull today and it doesn't work. See attachment for the Ruby Console.
      Thanks in advance.
      • W
        wohguandot
        And it also pop up a 'Load Error' message when I open Sketchup. See the error message below. Thank you.
        Error: #<FrozenError: can't modify frozen class: Traductor::Marshall>
        c:/users/s155785/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6marshall.rbe:46:in <class:Marshall>' c:/users/s155785/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6marshall.rbe:41:in module:Traductor'
        c:/users/s155785/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6marshall.rbe:23:in <main>' c:/users/s155785/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:333:in eval'
        c:/users/s155785/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:333:in require' c:/users/s155785/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:333:in require_ruby'
        c:/users/s155785/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:255:in load_body' c:/users/s155785/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6marshall.rbe:32:in initialize'
        eval:1:in initialize' c:/users/s155785/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6vault.rbe:47:in new'
        c:/users/s155785/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6vault.rbe:47:in initialize' c:/users/s155785/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6vault.rbe:33:in new'
        c:/users/s155785/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6vault.rbe:33:in instantiate__' c:/users/s155785/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6vault.rbe:34:in instantiate'
        c:/users/s155785/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:140:in initialize__' c:/users/s155785/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6chromiumwdlg.rbe:71:in initialize'
        c:/users/s155785/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6upgrade.rbe:837:in new' c:/users/s155785/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6upgrade.rbe:837:in initialize__'
        c:/users/s155785/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:160:in initialize' c:/users/s155785/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:153:in new'
        Error: #<NameError: undefined local variable or method initialize__' for #<Traductor::Marshall:0x0000026e0be0aee0> Did you mean? initialize initialize_dup> c:/users/s155785/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6marshall.rbe:33:in initialize'
        c:/users/s155785/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:153:in show' c:/users/s155785/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:66:in time_for_check?'
        c:/users/s155785/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:453:in block in after_startup' c:/users/s155785/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/su_pcp/pcprootproxy.rbe:110:in show_modal'
        c:/users/s155785/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/su_pcp/pcprootproxy.rbe:110:in show_dialog' c:/users/s155785/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/su_pcp/pcprootproxy.rbe:162:in module:SUPCP'
        c:/users/s155785/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/su_pcp/pcprootproxy.rbe:10:in `<main>'
          Follow steps here...
          https://sketchucation.com/forums/viewtopic.php?p=687098#p687098
