    Control Points Bezier Curves
    7 Posts 3 Posters 248 Views 3 Watching
      MLUY
      Does anybody know how to get the co-ordinates of the control points of a Bezier curve?
      I am using Fredo6 BZ_Toolbar and I have been unable to figure it out
      Any help / tips appreciated, perhaps I need another plugin (which?) but I really like this one
      Thanks!
      Michiel
        Usually I approach it from the other direction and create identifiable location for the control points of the Bezier curve. Would that be possible in your case?
        Are you still using SketchUp 2015 Make as your profile indicates?
        • fredo6F Offline
          fredo6
          One possibility is to convert the original to Polyline, which will give you the sequence of control points. Indeed, make a copy of the original bezier curve before.
            MLUY
            Thanks Dave!
            That would not work in my case as I want to trace a shape (imported image) and then I trying to adjust set the control points to get the shape I need
            Oh I need to update that, I am using Sketchup pro 2019
              MLUY
              wow, I am honoured to get a response from the great Frodo himself!, you are a absolute hero just wanted to say that.
              But I am not quite sure what you mean, because if I convert the bezier curve to a polyline (which I did) I just get a polyline....where are the control points ?
                MLUY
                oops too fast I got it now!, thanks very much!!
                  MLUY
                  oops initial response too fast I got it now!, thanks very much!!
