    How to construct a dome?
    8 Posts 4 Posters 524 Views 4 Watching
      Alohaa
      Hello,
      around the central vertical line in the attached file I want to construct a dome with a hollow star-shaped object going vertically through the whole material.
      The purpose: a roof for the tower also contained in the file.
      Note: the construction should change from a rectangular ground plan that fits inside the top of the tower to a circle.
      The dome should protrude 5mm from the side of the tower.
      All my attempts to construct such an object have failed so far.
      Actually, I would also like to add one or more moons on the side that fits the curvature and that goes vertically (it has to be vertical because I want to mill the whole thing and I can't mill at an angle), through the whole material, but that is even more complicated and probably too complicated.
      Sincerely
      Alohaa
      Kuppel.skp
        Alohaa
        ...and ideally the dome would be hollow, with a wall thickness of 8mm.
          samodelkin_77
          I'm not sure I understood you correctly, but suddenly I guessed right))
          Kuppel 1,1.skp
            Alohaa
            Thank you very much for all that work!
            It's almost what I wanted. The only thing I had imagined differently: at the bottom it should start as a square and stand about 5mm above the edge of the tower, and then go into a curve; the base should be like in the attached picture - I didn't find a better example-, at the top of course different because there is a star-shaped cut-out there. I don't know if this is possible with SU.
              Alohaa
              I managed to construct a dome myself, but probably in a more complicated way than SU allows. There's probably a simpler solution of copying the inside of the dome and enlarging it to construct the outside; I drew both line by line, and it eventually worked out.
              Above I cut out a star, but I didn't know how to put it on the dome, so I created a separate GCode for the star.
              Dome.skp
              • HornOxxH Offline
                HornOxx
                ...just as a suggestion Alohaa - if you downsave your SKP file posted here, e.g. to version SkUp 2017, you would give almost everyone here the opportunity to deal with your questions πŸ˜‰
                never trust a skinny cook
                • ely862meE Offline
                  ely862me
                  Once you have the desired profile shape you can use follow me. An then intersect geometry to subtract the star shape. But I believe your method is better when working with the cnc. Mill the star afterwards.
                  Elisei (sketchupper)
                  Come and See EliseiDesign
                    Alohaa
                    "downsave your SKP file posted here"
                    oh yes, sorry, I had forgotten that
                    The follow me method is indeed much more efficient.
                    I should try if the mill has a problem with a structure generated by that method.
                    Dome 2017.skp
