    Having trouble making face
    5 Posts 2 Posters 193 Views 2 Watching
    • O Offline
      olso5345
      Hi All, I am having trouble trying to get the attached skp into a co-planar face. I tried to purchase S4U Make Face extension - but it doesn't seem to recognize that it has been purchased. Can anyone assist in opening the attached and making it into a face? Many Thanks! Jeff. ( olso5345@umn.edu. )roadway and parking lot.skp
        You main problem is that your roadway edges are not in the same plane. Even with an extrension for creating faces you'll have a problem. Flatten the drawing first.
          There are some place where you won't get separate faces such as in the corner near the bottom here due to the gap. And since the perimeter of the parking area doesn't for a closed loop of edges, you won't have faces there, either.
          • O Offline
            olso5345
            Thanks Dave R! How do you flatten a drawing in SU Pro?
              There are a variety of plugins/extensions that can flatten geometry. TIG's Flatten to Plane is a good one. You can get it from the Sketchucation Extension Store.
