    Suggested pc spec. Thoughts?
    5 Posts 3 Posters 484 Views 3 Watching
      The following has been suggested as a spec for my next pc, any thoughts?
      Components list:
      1x Chillblast Fusion Custom PC
      1x 5 Years Warranty, 2 Years Collect and Return UK only*
      1x Estimated 1Β½ - 2Β½ Weeks Build Service
      1x Fractal Design Torrent Compact Case - Black
      1x Intel Core i5-13600KF CPU, 14 Cores* / 20 Threads, 3.5 - 5.1GHz
      1x Asus ROG STRIX B660-A GAMING WIFI D4 Motherboard
      1x Noctua NH-D15 CPU Cooler
      1x 64GB Corsair Vengeance LPX Black DDR4 3200MHz Memory (2 x 32GB Sticks)
      1x 1TB Samsung 980 PRO M.2 PCIe Gen 4 Solid State Drive
      1x Pre-Install Cabling for Additional Solid State Drive
      1x Pre-Install Cabling for Additional Hard Drive
      1x Windows 11 Home
      1x Corsair RM850X 80 PLUS Gold 850W PSU
      1x NVIDIA GeForce RTX 3080 10GB GDDR6X Graphics Card
      • G
        Glenn at home
        Looks good to me. That 13th gen i5 seems to be the "sweet" spot for single threaded and multi-threaded performance. It scores very well for what it is on the Passmark's CPU single thread rating, even better than an M2 πŸ˜‰
          Cheers mate, at least I can rest easy knowing it's reasonable overall.
            That's a nice setup you'll have. It'll blaze through renders if you move to one that supports GPU rendering.
            Even on CPU it'll chew up renders fast enough.
              Ta Rich, this is suggested for monitor, occasional gaming use so I hope it will manage renders with good enough resolution. https://www.cclonline.com/xub2796qsu-b1-iiyama-prolite-xub2796qsu-monitor-27-inch-2560-x-1440-qhd-ips-panel-amd-freesync-black/
