    Sketchucation Tools error on MacBook
    2 Posts 2 Posters 216 Views 2 Watching
    • H
      hambuild
      Hello All-
      I'm using SketchUp 2021 on a MacBook Pro running Catalina. I've tried to install Sketchucation Tools several times and get this message when I open SU.
      Error Loading File SketchUcation.rb
      Error: #<Errno::ENOENT: No such file or directory - getcwd>
      /Users/name/Library/Application
      Support/SketchUp 2021/SketchUp/Plugins/
      Sketchucation.rb:61:in 'pwd'
      Sketchucation.rb:61:in 'Module:SCF'
      Sketchucation.rb:17:in 'top (required)>'
      I have Sketchucation Tools successfully installed and running on a windows machine. Is that the issue? Am I only allowed 1 seat of SCF at a time? If so, I understand and will comply. πŸ‘
      Thank you!
      • TIGT
        This is because there's a weird error with Ruby interpreters on some MAC's...
        The loader file Sketchucation.rb tries to set up the ' TEMP' folder as it loads.
        But as a fallback it currently uses Dir.pwd to set at least some folder if the other more likely folder-paths fail.
        We will remove this in the next update of the toolset, even if the MAC error is not fixed, as it was a bit 'belt-and-braces' and that path was very very unlikely to be needed.
        Here's a fix you can make before we issue an update, note that because if will break the current 'signing code', you will need your Extension Manager > Loading Policy set to 'Unrestricted' to let it load properly...
        Open the file ../Plugins/Sketchucation.rb in a plain-text-editor [not a wordprocessor].
        Find line #60 and edit that, and line #61 below it...
        It originally says:
        '/tmp', Dir.pwd
        change it to read:
        '/tmp'#, #Dir.pwd
        with two added # symbols to stop the text following them being read...
