    Can't push pull a curved surface
    7 Posts 2 Posters 1.7k Views 2 Watching
      I have just drawn a flat shape with the intension of push pulling the surface. However when attempting this operation I get the " can't push pull a curved surface> I have seen this before with surfaces I was covinced were flat. However this shape took some time. Does anybody know why this occurs and perhaps a solution to extrude this "flat" shape?
      • BoxB Offline
        Attach your model.
          Thanks, here it is, but I have chopped it into pieces to push pull bit by bit for diagnosis.
          For box.skp
          • BoxB Offline
            Turn on hidden geometry and you can see the issue. You have an soft edge running along the notches.
            Remove those edges and it will be a single face.
            Whenever you get that error turn on hidden geometry and look for the joint.
              Nice work as usual, thank you πŸ˜„
              • BoxB Offline
                Your geometry is very slightly skewed, I believe probably due to having length snapping enabled.
                Go to Model Info/Units and turn it off in all your templates.
                  Cheers box. I have done it but do not really understand it I must admit πŸ˜• πŸ˜„
