    Plug in Manager not finding other folders
    3 Posts 2 Posters 668 Views 2 Watching
    • A
      alimac
      I have used the SkechUcation Plug-ins Manager for a long time, and it has, for the most part, worked flawlessly.
      I have my plug-ins separated into different folders by the creator.
      I use the 'Additional Folders for Plugins' to load up each folder when I open SU.
      It used to be that when I opened the SkechUcation Plug-ins Manager, I could see the different folders from the drop-down list and I could turn them on/ off as necessary.
      The drop-down list no longer works it only shows the original SU folder - I've tried reinstalling/restarting etc.
      Before I go through and rename ALL the rb! to rb is there a pref file that needs to be deleted that might make it work?
      Any pointers are appreciated.
      ![The drop down only shows the main SU plugins folder.
      Not all the different folders.](/uploads/imported_attachments/AV6x_Screenshot2022-10-12173847.png "The drop down only shows the main SU plugins folder.
      Not all the different folders.")
      • TIGT
        If you had registered your alternative Plugins folders [by using Fredo's tool = which I suspect is the issue...] then they appear in the list you showed, but you do need to use the down-arrow on the top-bar listing the current Plugin folder [defaulted to your standard folder] - the drop- down list them allows you to access any Plugins in the alternative folder you select...
        • A
          alimac
          Tig,
          Thanks for taking the time to reply (love your work BTW)
          It used to work perfectly and as you say, click the drop-down, giving me a list of the folders loaded up.
          I had my plug-in on G:drive but moved to my local πŸ˜„ drive as Google was missing files when syncing.
          I've just moved back to G: and now it works.
          There is something it doesn't like or doesn't have permission to look at folders on πŸ˜„ drive.
          Odd.
          We carry on!
          Cheers,
