Arrrrg! messed up view? How did I do this?
I know its something that I switched by mistake, but I can't figure it out. I did it before a long time ago. Also, If I was to send this file to someone else, would this setting be included in the file?
It's called clipping. It often happens when the camera is set to Parallel Projection and the camera is incorrectly placed. It can also happen when there is geometry at a vast distance from the rest of the model or the model is a long way from the origin.
If you save the file with clipping visible, we should be able to see it if you'd share the file. That would be a good way to get an exact answer and fix.
Register LoginAdvertisement
