    Section plane issue
    6 Posts 2 Posters 4.7k Views 2 Watching
    • L Online
      Hi, I have often used section planes. However I am having issues ATM. What am I doing wrong?
      • BoxB Offline
        It would help if you actually asked a question.
        If you mean there is no cut, perhaps you have turned the plane off individually or in view.
        You can right click on the section and select Active Cut.
        If this isn't the issue could you perhaps add the model and a description of the problem
        • L Online
          This is what I get when I use active cut.
          • BoxB Offline
            Go to view and untick, Section Fill.
            • L Online
              Here is model
              Section cut.skp
              • L Online
                Got it thank you
