CabMaker CutMaster Joinery missing joint holes
Dear CabMaker and CutMaster users,
Having spent two full days on learning both amazing tools. I now want to throw my screen through the window as I cannot find a solution/reason for this:
The created DXF file shows there are no holes drilled/machined/mitered in sides of the top panel. Only in the side panel. So I cannot join both parts like this. Unless I get my own drill to do the whole thing manually of course.
Is this a setting I did not turn on? Is it supposed to be like this? Also the bottom does not have holes in it.
See attached picture.
Thanks a lot already!
Register LoginAdvertisement
