    Medeek Wall 2D symbol height
    3 Posts 3 Posters 3.3k Views 3 Watching
    • joshtaysJ
      joshtays
      Sorry if this has been asked, I tried to search first, and I'm sure I'm just glossing over an obvious setting.
      Does anyone know a way to offset the 2D symbols for Medeek wall plugin so that they sit above finished floor level instead of at plate height? I tried vertical offset of door, but that only seems to move the 3d Data, not the 2D.
      Thanks all.
      • jujuJ
        juju
        Thanks all.
        You'll need to locate the symbols and change the SKP, save it (same name, everything) in same location. Be sure to save a backup somewhere as well, could get overwritten with future Medeek updates.
        • medeekM
          medeek
          In the General tab of the Global Settings there is a parameter to do just this:
          Version 2.1.4 - 05.29.2021
          Added an option for vertically offsetting text and symbols within the General tab of the Global Settings.
          Annotation text and symbols for doors, windows, garage doors, columns, Simpson Strong walls, and shear walls can be vertically offset a custom amount from the bottom of the wall.
          Nathaniel P. Wilkerson PE
          Medeek Engineering Inc
          design.medeek.com
