    CTRL Copy toogle not working in SU2021!
    2 Posts 2 Posters 1.8k Views 2 Watching
    • C
      CalypsoArt
      Very weird. Discovered it in a .skp file exported from Rhino. Move with CTRL toggle does not copy.I opened in SU2019, and the same process works as expected. Copies are made. I though it might be a problem with the export, but I've discovered starting a new file in 2021 the problem remains. Selecting an object > move then the CTRL toggle does not copy the object.
        Which 2021 version are you using?
        Are you holding Ctrl? In 2021 it's a tap and release to activate it.
        Click on the picture to make the GIF run.
