    [Plugin] Clipping Fix - v1.0.1 - 10 July 2021
    8 Posts 6 Posters 5.6k Views 6 Watching
    • samuel_tS Offline
      samuel_t
      This free SketchUp plugin allows you to fix "Camera Clipping Plane" issue in one click. Note this plugin isn't compatible with macOS.
      Demo
      https://i.ibb.co/3NNYVpG/Clipping-Fix-Sketch-Up-Plugin-Demo.gif
      Download
      Get Clipping Fix plugin from the SketchUcation PluginStore.
      • samuel_tS Offline
        samuel_t
        1.0.1 version fixes "first window stays open" issue.
        Download latest Clipping Fix plugin from the SketchUcation PluginStore.
        • judedouchJ Offline
          judedouch
          Hi, Samuel
          Thank you so much for doing this.
          Works fine.
          Simple is best.
          judedouch
          https://zupimages.net/up/21/27/9ozf.gif
            rv1974
            Its designed to fix clipping in perspective views only, right?
              judedouch
              Yes, you're right.
              judedouch
                joelle BRUN
                Bonjour,
                est-ce qu'il existe un plugin identique pour mac ?
                Merci pour votre aide
                • Z Offline
                  Zxen
                  Wow, I'm one of the first commenters. As you can see in this screenshot, I get an error message '1 Num Lock On' each time I try this plugin and clipping doesn't go away. I am in Camera Perspective mode. I don't know why anyone would create a plugin specifically for keyboards with number pads. Is it incompatible with Sketchup Pro 2023?
                  Clipping Fix Error
                  • I Offline
                    i5963c
                    Hello, it appears to me that this plugin 'toggles' between two states ('far' and 'near'). However, there is nowhere a visual clue about the actual state of the viewport.
                    Therefore, I have a suggestion/request:
                    Wouldn't it be possible to differentiate between the 'near' and 'far' status? This would be very helpful, I believe.
                    The differentiation should be made visible, both in the menu system and via the icon in the toolbar.
                    I assume that the 'far' status will be the 'default' one. If a user wants to switch to 'near', this can be done, either via clicking the toolbar icon, as well as by checking the 'Clipping Fix' entry in the Camera menu. The menu entry should then be preceded with a checkbox, while the toolbar icon could e.g. change or show a 'pressed icon'.
                    Obviously, both visual clues (i.e. checkbox in menu and icon in toolbar) should remain 'in sync' at all times.
                    Thanks to consider this request/suggestion.
                    Kind regards.
