[Plugin] LordOfTheToolbars - v4.1a - 20 Oct 26
Hello Fredo, it's been a while since the "Make Unique All Level" function doesn't work.
Also could you add more of native sketchup tools (with new icons) please ?
Thank you so much for your hard work !
Hi Fredo! Thank you for such a great extension! I was trying it out today, And I realized that the new(ish) Flip tool was not showing up in the master toolbar manager. Is there a reason for this? Thanks for a great management solution.
I am looking to completely remove lord of the toolbars, not going so well, any tips?
NEW RELEASE: LordOfTheToolbars v2.8a - 10 Nov 24
Requirements
- LibFredo6: v14.7a or above
- Sketchup version: SU2017 and above
LordOfTheToolbars 2.8a is a maintenance release including:
- Fix related to the insertion of icons in palettes.
Home Page of LordOfTheToolbars for information and Download.
@GiordanoBernard92 said in [Plugin] LordOfTheToolbars - v2.8a - 10 Nov 24:
@fredo6
again, sorry for the late reply, I don't get email notifications for the forum.Yes. both LibFredo6 and LOTT are updated.
Here is the ruby console dialog:
Error: #<RangeError: invalid codepoint 0xD83D in UTF-8>
c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:6125:inall_menus' c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:6125:inmenu_mapping'
c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:6203:inmenu_structured_list' c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsfinddialog.rbe:219:inprepare_data'
c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsfinddialog.rbe:136:indialog_invoke' c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmanager.rbe:5379:inminifind_invoke'
c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsvignettedialog.rbe:888:inminifind_invoke' c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsvignettedialog.rbe:619:indialog_callback_exec'
c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsvignettedialog.rbe:588:indialog_callback' c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2456:incall'
c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2456:inmaster_callback' c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2221:inj_action'
c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2180:inj_callback' c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2166:inblock in j_dispatch'
c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2158:ineach' c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2158:inj_dispatch'
c:/users/giordano/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:1436:in `block in create_dialog'@fredo6 were you able to understand the problem here?
anybody having the same issue, the search funcion not working anymore?
Do you have any plugin displaying a menu in Chinese or Eastern language?
Also, old versions of some plugins made by Samuel Tallet (Universal Importer, Parametric Modeling) were cuasing problems because the menu texts included diacritic characters.
@fredo6
I've got to check, I'll answer back as soon as I have.
If I didn't explained myself well, the vignette stripe works but if I click on the search button on it, the dialogue box for searching commands do not pop up. -
@fredo6
I disabled a whole lot of plugins and now it works, I'm going to make a search activating them one by one and I'll let all know which are giving the problem,
already thank you so much, I just love that function -
@fredo6
I had Phisically Based Render, that gave the trouble -
Hello Fredo, I'm missing greatly in the dialogue box Master Toolbar Manager, in personnal commands and in Menu the accès to all sketchup tools to ad icons. When I open New personal Command (menu) the list is empty. I would realy need it.
Why was it working in the olds version and know it doesn't ?Thanks
If you could fix that it would be a great tool. -
@laurent002
The limitation of functionality as of SU 2023 is due to a change of UI framework in Sketchup (called Qt), which does not allow any longer to access menus.It still work in older SU version and on Mac, all versions.
@laurent002 said in [Plugin] LordOfTheToolbars - v2.8a - 10 Nov 24:
It's very sad, it is realy missing in sketchup to ne able to organise and use any tools as we wish, any tools or fonction. And the question of having so many plugin creators, sometine with no icons, or not all tools, is a great limitation. You can't créât to many short cuts, to make your flow more cohérent. Going to the menu, then using icon, and adding a short cut, is moving your mouse all over your screen, going from one side to the other. It give sketchup a look of a very old sofware, when other software have a much better ergonomi. What sketchup should be so plugin designers and users would be able to juste work without having to thinks how to adapt there work to sketchup, but how to ajuste sketchup to there work. -
After version 2.4a there is a very big compatibility issue with SU 2022 (and maybe also with previous SU versions.!), that makes SU barely usable - I've spent 6-8 hours trying to understand what the hell is wrong with my SU...
Now maybe I would have to pair it with a LibFredo version..., but today I've spent my energy reserves.
Sometimes (rarely) I use SU 2022, for compatibility with other plugins or for printing options that have disappeared starting with SU 2023.
Anyway, a bug (any bug.!!) in LOTT affects the SU engine, so you have the choice to use it or throw it away completely. -
First thing would be to upgrade both LibFredo6 and LOTT to their latest published versions.
Second, can you describe the 'bug' you have with SU2022?
@fredo6 They already were in the latest version (otherwise I wouldn't come here to write).
There was no "one single" bug - SU and the entire OS were almost frozen, you had to wait for a few minutes before you had any access to SU and also to the OS (W 11)... for about 1-2 minutes, and then the same cycle... (flashing and freezing... and couldn't use no other app).Experience (a lot of it) and intuition finally drove me to LOTT - and I made no other changes in my PC other than downgrade LOTT (LibFredo seems to be fine at the second to last version) - It has been a few hours and everything is alright (I mean as much as it can it can be after W7).
This kind of problem started on many levels with SU (and its plugins) only after W7, but unfortunately, we are not in the driver's seat... and we have to move forward, everything was flawless but starting with W10... many headaches for users and developers, concerning many other software.
@FlorinAp All these incompatibility issues between SU 2022 and W10-W11 have disappeared starting with SU 2023, and maybe at some point not everything can be compatible with everything... i understand that, but it is fair that at that point every developer should mention in its release notes where the compatibility ends.
If it helps - your release notes are very helpful.!
@FlorinAp Sorry, i was a bit irritated after so many wasted hours, and I missed telling you something - everything was starting as soon as I would approach my mouse to any palette, if you wouldn't touch the palette... everything was fine.
Although SU 2022 would load very late and very slowly because of the vignette, but after that you are not allowed to touch any pallette; but if I disbaled the LOTT completely, SU would also load very fine and fast.
I hope it helps...!
LOTT is compatible with SU2022. It even includes menu command.
So what exactly is the problem.
Can you exit SU2022 with the Ruby console opened and relaunch SU2022. The Ruby console should open at startup and log potential errors.
@fredo6 I don't know what is the problem, but even with 2.4a SU 2022 is not usable, with 2.4a it just doesn't freeze my os anymore, but SU 2022 it is still mostly unusable, the only way to make it usable is to disable LOTT completely.
Since I wrote that everything is alright I haven't used it, I just left it there, opened in background, to understand now that I cant use it... if I don't disable LOTT.
I will try what you suggested...!
@FlorinAp Well man, below is the content from the ruby window, for me is an alien language, but maybe you can make sense of it...!
For me is not a big deal because now I use mostly SU 23 and 24 - it's just a sick incurable stubbornness to understand and fix everything I touch, so if it makes sense to you maybe you will be willing to share; I don't see nothing "Fredo" related, but it seems to be a conflict created by some Curic extensions...."finished reading language file
tb_mode,single
tb_Settingout,true
tb_Draw,true
tb_Edit,true
tb_Array,true
tb_Wall,true
tb_Staircase,true
tb_Win,true
tb_Roof,true
tb_Site,true
tb_Structure,true
point_on_face,true
divide,true
align,true
perpendicular_line,true
fonplane,true
bestface,true
extrude1,true
extrude2,true
move_vertex,true
fillet,true
chamfer,true
extend,true
offset_edge,true
hline_faces,true
slopeedges,true
linear_array,true
rect_array,true
polar_array,true
path_array,true
wallsctrl,true
opening,true
hgroove,true
escalator,true
wframe,true
dframe,true
paneldivide,true
screen1,true
hlouvres,true
vlouvres,true
joists,true
roof1,true
hiproof,true
revsurf,true
mdeck,true
stairsctrl,true
profiles_on_plane,true
cutfill,true
siteb,true
fndctrl,true
columnctrl,true
contour,true
setlayer,true
mergelayer,true
framesel,true
scale,true
center1,true
ptsinfo,true
extrude3,true
profiles3d,true
extrude0,true
loading 1001bit pro menu >> true
c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/dbur_projections/dbur_projections.rbe:5: warning: already initialized constant Math::PROJEPSILON
c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/dbur_guidetools/dbur_guidetools.rbe:6: warning: previous definition of PROJEPSILON was here
true
Sketchup Version is = 17
88
"icon_thickness_mode.svg"
"c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_dio2/Resources/icon_thickness_mode.svg"
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/cmap/subtable.rb:13: warning: already initialized constant TTFunk::Table::Cmap::Subtable::ENCODING_MAPPINGS
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/cmap/subtable.rb:13: warning: previous definition of ENCODING_MAPPINGS was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:6: warning: already initialized constant TTFunk::Encoding::MacRoman::TO_UNICODE
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/mac_roman.rb:6: warning: previous definition of TO_UNICODE was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:42: warning: already initialized constant TTFunk::Encoding::MacRoman::FROM_UNICODE
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/mac_roman.rb:42: warning: previous definition of FROM_UNICODE was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:50: warning: already initialized constant TTFunk::Encoding::MacRoman::POSTSCRIPT_GLYPH_MAPPING
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/mac_roman.rb:50: warning: previous definition of POSTSCRIPT_GLYPH_MAPPING was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:6: warning: already initialized constant TTFunk::Encoding::Windows1252::TO_UNICODE
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/windows_1252.rb:6: warning: previous definition of TO_UNICODE was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:18: warning: already initialized constant TTFunk::Encoding::Windows1252::FROM_UNICODE
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/windows_1252.rb:18: warning: previous definition of FROM_UNICODE was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:26: warning: already initialized constant TTFunk::Encoding::Windows1252::POSTSCRIPT_GLYPH_MAPPING
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/windows_1252.rb:26: warning: previous definition of POSTSCRIPT_GLYPH_MAPPING was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:9: warning: already initialized constant TTFunk::Table::Glyf::Compound::ARG_1_AND_2_ARE_WORDS
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:9: warning: previous definition of ARG_1_AND_2_ARE_WORDS was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:10: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_A_SCALE
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:10: warning: previous definition of WE_HAVE_A_SCALE was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:11: warning: already initialized constant TTFunk::Table::Glyf::Compound::MORE_COMPONENTS
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:11: warning: previous definition of MORE_COMPONENTS was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:12: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_AN_X_AND_Y_SCALE
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:12: warning: previous definition of WE_HAVE_AN_X_AND_Y_SCALE was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:13: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_A_TWO_BY_TWO
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:13: warning: previous definition of WE_HAVE_A_TWO_BY_TWO was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:14: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_INSTRUCTIONS
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:14: warning: previous definition of WE_HAVE_INSTRUCTIONS was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:20: warning: already initialized constant TTFunk::Table::Glyf::Compound::Component
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:20: warning: previous definition of Component was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/hmtx.rb:22: warning: already initialized constant TTFunk::Table::Hmtx::HorizontalMetric
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/hmtx.rb:22: warning: previous definition of HorizontalMetric was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/post/format10.rb:5: warning: already initialized constant TTFunk::Table::Post::Format10::POSTSCRIPT_GLYPHS
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/post/format10.rb:5: warning: previous definition of POSTSCRIPT_GLYPHS was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/sbix.rb:11: warning: already initialized constant TTFunk::Table::Sbix::BitmapData
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/sbix.rb:11: warning: previous definition of BitmapData was here
c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_oi/loader.rbe:169: warning: already initialized constant CURIC::OI::PLUGIN
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi.rb:6: warning: previous definition of PLUGIN was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/cmap/subtable.rb:13: warning: already initialized constant TTFunk::Table::Cmap::Subtable::ENCODING_MAPPINGS
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/cmap/subtable.rb:13: warning: previous definition of ENCODING_MAPPINGS was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/mac_roman.rb:6: warning: already initialized constant TTFunk::Encoding::MacRoman::TO_UNICODE
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:6: warning: previous definition of TO_UNICODE was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/mac_roman.rb:42: warning: already initialized constant TTFunk::Encoding::MacRoman::FROM_UNICODE
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:42: warning: previous definition of FROM_UNICODE was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/mac_roman.rb:50: warning: already initialized constant TTFunk::Encoding::MacRoman::POSTSCRIPT_GLYPH_MAPPING
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:50: warning: previous definition of POSTSCRIPT_GLYPH_MAPPING was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/windows_1252.rb:6: warning: already initialized constant TTFunk::Encoding::Windows1252::TO_UNICODE
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:6: warning: previous definition of TO_UNICODE was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/windows_1252.rb:18: warning: already initialized constant TTFunk::Encoding::Windows1252::FROM_UNICODE
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:18: warning: previous definition of FROM_UNICODE was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/windows_1252.rb:26: warning: already initialized constant TTFunk::Encoding::Windows1252::POSTSCRIPT_GLYPH_MAPPING
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:26: warning: previous definition of POSTSCRIPT_GLYPH_MAPPING was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:9: warning: already initialized constant TTFunk::Table::Glyf::Compound::ARG_1_AND_2_ARE_WORDS
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:9: warning: previous definition of ARG_1_AND_2_ARE_WORDS was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:10: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_A_SCALE
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:10: warning: previous definition of WE_HAVE_A_SCALE was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:11: warning: already initialized constant TTFunk::Table::Glyf::Compound::MORE_COMPONENTS
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:11: warning: previous definition of MORE_COMPONENTS was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:12: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_AN_X_AND_Y_SCALE
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:12: warning: previous definition of WE_HAVE_AN_X_AND_Y_SCALE was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:13: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_A_TWO_BY_TWO
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:13: warning: previous definition of WE_HAVE_A_TWO_BY_TWO was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:14: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_INSTRUCTIONS
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:14: warning: previous definition of WE_HAVE_INSTRUCTIONS was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:20: warning: already initialized constant TTFunk::Table::Glyf::Compound::Component
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:20: warning: previous definition of Component was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/hmtx.rb:22: warning: already initialized constant TTFunk::Table::Hmtx::HorizontalMetric
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/hmtx.rb:22: warning: previous definition of HorizontalMetric was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/post/format10.rb:5: warning: already initialized constant TTFunk::Table::Post::Format10::POSTSCRIPT_GLYPHS
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/post/format10.rb:5: warning: previous definition of POSTSCRIPT_GLYPHS was here
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/sbix.rb:11: warning: already initialized constant TTFunk::Table::Sbix::BitmapData
C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/sbix.rb:11: warning: previous definition of BitmapData was here
"RubyEncoder loader: C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_true_isolate/rgloader/rgloader27.mingw.x64.so"
c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_axis/utils.rbe:123: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_space/utils.rbe:374: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/projection/projection.rbs:23: warning: already initialized constant Math::PROJEPSILON
c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/dbur_projections/dbur_projections.rbe:5: warning: previous definition of PROJEPSILON was here
Tolerance default to 0.001
radius = xxx
segmentation = xxx
delete_corners = xxx
radius = xxx
segmentation = xxx
"Add help menu!"
"create new"
"created"
#Sketchup::Menu:0x000001d455838b98
(eval):23: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
"Add help menu!"
"created"
"created"
(eval):23: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open"
Register LoginAdvertisement
