βΉοΈ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
Practice makes better
What a difference. I had no idea the change in quality of my renders had come this far.
Both renders are Raylectron. First one is one of my early renders from 4 years ago. The second one is from just a few months ago. Same PC. Same version of Raylectron. Same materials, except for the vines on the outside wall.
Practice does indeed help, nice one mate.
Definitely. Kudos!
Excellent ! It's good to look back at earlier work to see how you've progressed. Helps to keep you energized.
Sehr gut!
"Practice makes better" - yes, practice together with patience and perseverance are the most important here - and for me coincidence was also a good companion often -
Thanks everyone. For the compliments, the encouragement and the help.
