    โš ๏ธ Important | Libfredo 15.6b introduces important bugfixes for Fredo's Extensions Update
    Tree leaf material issue
    7 Posts 3 Posters 1.6k Views 3 Watching
    • K Offline
      Kontroliora
      Hi, guys!
      I have some problems with the leaf material. Basicly it is the png texture that i use like transperancy, but its getting appears strange white lines around the leafs. I put a opacity map with erased 1 pixel from the all leaf from the textures but without succssed. The result are decent when i am zoom in to the tree but if i getting zoom out, the trees and liefs is geting became white and this green color is getting washed out. Why this white lines around the leafs is happened and did you khow how to fix this issue. Thks in advance!
      • Bryan KB Offline
        Is this happening when you render?
        • K Offline
          Kontroliora
          Yes, It is happened when i render. Is there anyone with the same issue.
          Vray 4.20
          • GD3DesignG Offline
            GD3Design
            Try turning off filtering for both diffuse & opacity bitmaps and make sure alpha map is set to linear space, 1.0, and not rendering space, rgb.
            also, easier to trouble shoot if you post skp file. cheers
            • K Offline
              Kontroliora
              Hi, Thanks for reply. I cant understand exactly how to turn off the filltering... if it is the antializing when i turn off, nothings happened. Also i made everything on linear space but without success. This is the link with the file. Try it if you have time .
              Thanks in advance
              https://we.tl/t-iyWuMArUDF
                GD3Design
                You need to click the little advanced settings button to unhide the advanced stuff for bitmap settings, then turn off filtering. Do this for both diffuse & opacity maps. Here is file, but I use latest vray so might not be backwards compatible. https://www.dropbox.com/s/vjynl83pk516a9d/Tree%20-%202.skp?dl=0
                • K Offline
                  Kontroliora
                  Thank you a lot man. You have 1 beer from me ๐Ÿ˜„ Be blessed!
                  I wouldn't have guessed it could be that!
