    Layout updating bug
    layout
    2 Posts 2 Posters 4.7k Views 2 Watching
    • E
      elizalili
      Hiiii
      I have a layout file with only one sketchup model inserted and different scenes made in sketchup
      ( once I´ve been told that the new layout feature that allows you to change the scenes in layout can cause bugs ). And whenever I update the model in the layout file it messes up my scenes by making the filling of the cut walls disappear. Even when the scenes in the layout seem to be okay, when I export it to a PDF the same thing happens!
      I´ll attach some images to illustrate what I mean by the "filling of the cut walls".
      Sorry for the broken english
      Hope you can fix my problem!
      Thank youu 😄
      walls without the hatch
      walls before things went wrong
        I doubt this is a bug. More likely it's incorrect scene and style setup. Share your LO file so we can see what you are getting and help you get it sorted out.
        This sounds like something you might have been told by someone who doesn't fully understand how to use scenes in LayOut.
