    Extension menu
    3 Posts 2 Posters 3.9k Views 2 Watching
    • kenK
      ken
      How are the plugins that appear in the extension menu arranged? I am wondering if I rename the plugins will they show up higher in the extension menu.
      What I would really like is folders like they have in the tag menu. I find the folder very helpful.
      So, folders in the extension menu would make grouping like type plugins in groups.
      • TIGT
        The 'loader' RB files in the Plugins folder load alphanumerically.
        You can try editing their names, however, in some cases it might break the main extension's code...
        Also it will probably break the 'signing' if the extension - but this is only an issue if your Extension Manager's Loading-Policy is not set to 'Unrestricted'...
        But it will be an administrative chore whenever an RBZ gets updated...
        • kenK
          ken
          Thanks, TIG
          So, I wanted "lock by layer" moved up in the menu structure. Change name from lockbylayer.rb to A lockbylayer.rb. Also changed the code "file loaded" to the new name.
          Moved up and still works.
          This was not obvious just by looking at the plugins in the plugin directory.
          Anyway, got it fixed. Would really like this plugin to be a toolbar plugin.
          And thanks TIG.
