    ๐Ÿ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    [Plugin] Parametric Modeling - v0.0.7 - 03 June 2021
    86 Posts 31 Posters 117.9k Views 31 Watching
    • samuel_tS Offline
      samuel_t
      With Parametric Modeling, a new free SketchUp plugin:
      • Do parametric modeling thanks to a Nodes Editor similar to Unreal Engine's Blueprints.
      • Modify entities parameters at any time and see result instantly.
      • Extract shapes, points and vectors from active model.
      • Import schema from a file. Export schema to a file.
      Demos
      https://i.ibb.co/cJzjSs5/Parametric-Modeling-Sketch-Up-Plugin-Staircase-Demo.gif
      https://i.ibb.co/WVRfFvT/Parametric-Modeling-Sketch-Up-Plugin-Shelf-Demo.gif
      Warning
      This plugin is still in beta. Compatibility between versions is not guaranteed.
      Download
      Get Parametric Modeling plugin from the SketchUcation PluginStore.
      • jenujacobJ Offline
        jenujacob
        is this going to be the grasshopper for sketchup in the future??? ๐Ÿ˜ฎ ๐Ÿ‘
        • samuel_tS Offline
          samuel_t
          Let's hope ๐Ÿ˜„
            Bravo! โ˜€
            Works fine! 2017 Make for me! ๐Ÿ˜„
            https://images2.imgbox.com/de/ed/pw2wldjZ_o.gif
              tenrev
              well done Samuel
              you are the best, I installed and I will do some tests
              tenrev
              biblio3d forum sketchup - artlantis - piranesi
              http://www.biblio3d.com
                jenujacob
                A cool tutorial from tutorials Up!
                • K Offline
                  kenancakir
                  Thank you.. ๐Ÿ˜
                  • K Offline
                    Kruegen
                    This is amazing!!!! Thank you so much for doing this. You have no idea how much time this will save me. Thank you!!!
                      cloo
                      Looks really cool, and a lot of work ahead.
                      Since you GPL it, do you have plans to move development to github or so and let other cool folks contribute to the progress?
                      • samuel_tS Offline
                        samuel_t
                        Yes. I will publish to GitHub the source code of this plugin in a near future.
                        • N Offline
                          numerobis
                          Very cool!
                          It would be great, if this could be made non-destructive / as modifier. But i suppose it's not possible with SketchUp to store the operations in the model/component. Maybe this could change in the future with LiveComponents...
                            lelam11234
                            Good plugin. But I have the suggestions.
                            1. Tab Number: It has an extra cell so we can name it
                            2. Tab Draw *** : It has an extra cell to Hide/Unhide
                              Thanks.
                            • srxS Offline
                              srx
                              Thank you! ๐Ÿ‘
                              www.saurus.rs
                              • samuel_tS Offline
                                samuel_t
                                  Thanks.
                                Thanks for your suggestions.
                                  turbodizayn
                                  Is there some manual? Sounds GRATE! If it is good I will donate)))
                                  • samuel_tS Offline
                                    samuel_t
                                    Help will be available from next version.
                                      jenujacob
                                      hi Samuel,
                                      Great plugin! i really hope this grows into something like GH for Rhino.
                                      now, I am no coder, and I have absolutely no idea how this thing works under the hood. But, would be it possible to click in the SU window to enter values for points instead of typing in the x.y.z coordinates?
                                      thanks!
                                      • P Offline
                                        pinoy
                                        This is good! Thank you
                                        • samuel_tS Offline
                                          samuel_t
                                          @jenujacob said:
                                          hi Samuel,
                                          thanks!
                                          Hi Jacob, Thanks! I'm thinking about a "Parametric Modeling > Extract Point From Construction Point" entry in context menu when a construction point is selected in SketchUp window. This would be a shortcut to add a "Point" node.
                                          • samuel_tS Offline
                                            samuel_t
                                            What's new in 0.0.3 version?
                                            • Node adding process was enhanced: one can place new nodes quicker!
                                            • One can extract vectors and points from active model via context menu.
                                            • In "Calculate" nodes, one can use rand function to get random numbers.
                                            • As soon a material or a layer is added or removed: Nodes Editor reloads.
                                            • A door is available in examples schemas. Thanks Simon Joubert for this.
                                            • Although it's not recommended, one can read/edit .schema files easier.
                                            Download latest Parametric Modeling plugin from the SketchUcation PluginStore.
                                            • 1 / 5
