    SketchUp Interior Design Tutorial—How to Create a Floor Plan
    2 Posts 2 Posters 5.2k Views 2 Watching
    • a2theoA
      a2theo
      Need to create a floor plan with SketchUp? We've created a YouTube video tutorial that walks you through the process in 7 easy steps. Based on the approach we teach in one of our paid courses, watch this video and you’ll avoid the problems people often run into when learning how to create a professional floor plan with SketchUp. Here's what we cover:
      1. Start in a "2D Template"
      2. Draw Your Floor
      3. Draw Your Exterior Walls
      4. Draw Your Interior Walls
      5. Add Your Windows & Doors
      6. Import Furniture & Fixtures
      7. Style Your Plan for Presentation
      You can watch the new video on our YouTube channel here: https://www.youtube.com/watch?v=oJ8UtjJgpQw
      When you get a chance, watch the video, and then be sure to let me know if you have any questions or feedback. Thanks!
      • R
        renasmith Newcomers
        Sure, I'd be happy to provide you with a SketchUp interior design tutorial on how to create a floor plan. Here are the steps:
        Open SketchUp and select "File" > "New" to start a new document.
        Click on the "Rectangle" tool in the toolbar, and then draw a rectangle on the workspace to represent the walls of your room.
        Use the "Push/Pull" tool to extrude the rectangle upwards to create the walls of your room.
        Use the "Line" tool to draw lines within the rectangle to represent the interior walls of your room. This will help you to create individual rooms within your floor plan.
        Use the "Rectangle" tool to draw rectangles within your walls to represent the doors and windows of your room.
        Use the "Push/Pull" tool to extrude the rectangles outwards to create the doors and windows.
        Use the "Eraser" tool to erase any overlapping lines or surfaces.
        Use the "Text" tool to label each room and each door and window within your floor plan.
        Use the "Measure" tool to check the dimensions of your rooms and doors and windows, and adjust them as necessary.
        Use the "Paint Bucket" tool to add colors and textures to your floor plan, such as different flooring or wall colors.
        Save your floor plan by selecting "File" > "Save As" and choosing a file name and location.
        That's it! By following these steps, you should be able to create a basic floor plan for your interior design project in SketchUp. Good luck and have fun designing!
