    Missing visible edges on one same group between two scenes o
    2 Posts 2 Posters 1.4k Views 2 Watching
    • W
      Woodarc
      Hi, guys can’t seem to figure this one out! In two separate ‘scenes’ of the same ‘style’ two identical ‘groups’ appear differently. The first shows all ‘edges’ of the ‘scene’, the second hides the edges on two (identical) groups only.
      I am I missing something obvious? tried turning on all etc and various other things including redrawing and re-inserting. Perhaps I’ve been working too much in isolation!
      Any thoughts or suggestions gratefully received
      Many thanks in advance
      image from model
        Probably a tag usage issue. Make sure you haven't assigned a tag to the edges and that tag isn't turned off. Make sure you are using tags correctly leaving all edges and faces untagged and only tagging objects (groups and components). Also make sure you are leaving Untagged as active. The pencil icon on the far right is always at Untagged.
