    Tutorial: How to Use Bump Maps in Vray Sketchup
    renderpluginsextensions
    1 Posts 1 Posters 5.4k Views 1 Watching
    • sunary0S
      sunary0
      hello everyone, this time I want to share tips on how to use bump maps in vray Sketchup
      Bump is a parameter used to give a material a raised impression. In order for the bump to work, a file called the bump file is needed
      The Bump parameter is usually only used for certain types of materials, for example ceramic materials, walls, wood, bricks and materials with textured surfaces.
      To create a bump file, you can use an image processing program such as Photoshop
      1. The first step, please enter the Asset Editor then select the Bump menu. If it's not already active, you can activate it by clicking the switch menu
      https://1.bp.blogspot.com/-JbHiCoejfUM/YAHR8gvTd3I/AAAAAAAABdU/uGXEuSg8hxobuHnZdUyFI29eCahOl5tDQCLcBGAsYHQ/s0-rw/bump-maps-vray-3.jpg
      1. Then click the Texture Slot at the top and select Bitmap
      https://1.bp.blogspot.com/-Wk7MXY1_7wA/YAHTgIPpa2I/AAAAAAAABdg/rtunkh72zlATt6r6MnT_tNCSZb6nGJOagCLcBGAsYHQ/s0-rw/bitmap.jpg
      1. At this stage, please upload the bump file that you previously prepared, after that make sure the color spacer is still Screen sRGB.
      https://1.bp.blogspot.com/-PM6zdEeMUQo/YAHVIX5iCsI/AAAAAAAABds/meqK6yre2L8d5UfZjUHGJXnF0wz__qhWwCLcBGAsYHQ/s0-rw/colorspace.jpg
      1. Finally, please set the bump value as needed. To change the value, just swipe right on the Amount panel.
      Result
      https://1.bp.blogspot.com/-7MrJo8t7u0Y/YAG6dwtyR6I/AAAAAAAABcY/qtu3twqjNaMTaCg2FTpooreZSISnecIWQCLcBGAsYHQ/s0-rw/cara-menggunakan-bump-vray-sketchup.jpg
      Using Bump and displacement does produce good images but the effect makes the rendering process take longer. To avoid this, you should not bump all materials unless our equipment has high specifications.
      I hope this tutorial was helpful β˜€
