    How to print guide lines and guide points
    2 Posts 2 Posters 1.2k Views 2 Watching
    • M
      Maxdalex
      Dear friends, I have looked everywhere and I could not find a way to print guide lines and guide points. When I print they are not considered. Since I use sketchup to generate plans for garden design I need to be able to mark the guide points (e.g. center of circles) on the ground and I need a plan in scale which shows these point. I use Sketchup Make 2016.
      In case this feature was only available in Pro or Layout, do you know of any plugin that transforms guide points into geometry?
      Thank you so much for your help.
      Massimo
        Guides are not printable in SketchUp. They could be made to show and print using LayOut or you could replace the guides with real dashed lines in LO. Using LayOut would give you better options for dimensions and adding text to the views, too.
        You should be using SketchUp Pro for your business instead of Make anyway.
