HELP: Dynamic Component Toolbar Missing, Mac
Hi All,
I'm currently using SketchUp Pro 2021 on a Mac and can't seem to find where the dynamic component toolbar is. The dynamic components I am using also don't seem to be responding to commands (scale, rotate, etc). Has this feature been removed from the Mac version of Sketchup? I typically use windows, so I am generally unfamiliar with the Mac format of Sketchup.
Greatly appreciate any and all support - thanks in advance!
Make sure Dynamic Components are Enabled in the Extension Manager. Then you should be able to find the toolbar in View>Tool Palettes. If you need to enable it click Apply Changes then quit and restart SketchUp to make sure it loads.
Thanks for the assistance, Dave!
Register LoginAdvertisement
