Exporting 98" wide jpg image
I'm producing an image for a large advertising sign and the graphic designer is asking for a 98" wide @ 200dpi jpg. I've adjusted my paper size to 98" wide and have imported my image from Sketchup. All looks completely normal. When I go to export to JPG or PNG, the image comes out completely blank and the file size is in the 1000kb range. What am I doing wrong? Any help would be greatly appreciated.
Thanks, Paul
Try exporting as PDF, with image resolution set to high, and then rasterizing in an image editor like photoshop or GIMP, with resolution set to 200dpi, and saving to jpg.
Edit:
Had success exporting up to 2000mm (78"). Any higher and the pdf came out blank. Maybe a hard limit set inside LO.
But, PDF output set to high will export at 300dpi, so changing image size, without resampling should get your 2500mm wide image at 200dpi without issue.
Register LoginAdvertisement
