    Texture export with DAE export
    3 Posts 2 Posters 3.0k Views 2 Watching
    • B
      BartD
      I downloaded a few models from the 3D Warehouse to use them in some custom scenery for the new Microsoft Flight Simulator.
      To create the models in MSFS, i need to
      1. Export them to a DAE file with textures
      2. With ModelconverterX convert them to a set of files, readable by the MSFS SDK (bin,obj and xml file)
      3. Run them through the SDK compiler to get a BGL file with everything needed to place the objects in MSFS
      When i export the objects to DAE, SU creates the textures as material*.tif. For a single object, all works well. I can perform step 2 and 3 and the object is available in MSFS for placement.
      Problems start when i add a second object.
      Export OK.
      Conversion with ModelconverterX OK.
      All the textures for the different models go into a single directory for compilation with the SDK. Problem: The previous object has textures with the same name.
      I tried solving it by saving the DAE with texture names ( https://sketchucation.com/forums/viewtopic.php?f=323&t=40397 ) but no go, when importing in ModelconverterX, the DAE still searches for the files material*.tif
      Any other solutions ?
        What version of SketchUp are you using? Your profile says 2021 Free/Make but that doesn't exist.
        • B
          BartD
          I am running the latest version in trial mode.
          And managed to find a solution myself late last night.
          DAE is basically a text file you can edit with any text editor. I changed the material*.tif to my original JPGs and got it working.
