    Collada DAE / 3DS export selection only outputs nothing
    4 Posts 3 Posters 7.0k Views 3 Watching
    • SminkyS Offline
      Sminky
      In ver.2021, when I try and export to DAE or 3DS using the "selection only" setting, it doesn't even create a file.
      I also tried exporting to an already created file, but doing this leaves the contents of that file unchanged.
      This is often used in our workflow so please advice.
      Best regards
        This has been reported so hopefully there'll be a fix soon. It seems to affect a number of the exporters including .stl and the ones you mentioned.
        • P Offline
          pp9441185
          This is a too amazing software to develop our creativity. When I create drawings such as illustration and cartoons. So it is an opportunity to improve your art. But if you want to get the best experience with this software so you should need a MacBook. if you want to get MacBook within your budget. while purchasing you must use the OWC PROMO CODE then you can get in your price
          • SminkyS Offline
            Sminky
            Thank you very much for the prompt response.
            Best regards
