    Axis Issue?
    4 Posts 2 Posters 1.9k Views 2 Watching
    • Joe WoodJ
      Joe Wood
      Hhmmm, this 2021 model is somehow skewed. This is the Top view, the model, and red axis, aren't parallel to the screen? Same with the other Views.
      I R clicked the axis and choose Reset but that didn't help. What happened folks?
      Joe Wood
      woodsshop.com/
        Standard views are not determined by the axis orientation. This is not unique to SU2021. It's been that way from the beginning. The standard views are fixed and not dependent on axes orientation at all. By default, the axes are oriented so in the top view the red axis runs left to right and the green runs vertically. If you rotated the axes from their default orientation and then created your model at an angle, it will be shown at an angle even if you reset the axes. At this point you should reset the axes and then rotate the model to align with them so you get the views you want.
        • Joe WoodJ
          Joe Wood
          thanks again amigo that did the trick, really appreciate all your help and I'm Glad I finally went with this 2021 pro!
          Joe Wood
          woodsshop.com/
            Good deal.
