    Fredo6 Round corners
    12 Posts 4 Posters 5.2k Views 4 Watching
    • kenK
      ken
      I can't get Fredo6 Round corners to work in ver 2020 or 2021. The attached image shows how the program is working/not working. On the first selection, when you select round edges, all of the selected edges to be rounded disappear. As shown in the first of the top illustration. All but the back wall has been removed.
      Yes, the program is up to date. This problem is in ver 2020 and 2021.
      • fredo6F
        fredo6
        Ken
        I guess you talk about FredoCorner.
        Could you open the Ruby console and check if there are errors displayed.
        There must be an explanation, because FredoCorner should work fine with SU2020 and SU2021
        • kenK
          ken
          Here is an image of the Ruby Console.
          • kenK
            ken
            And I get this in ver 2020
            problem with draw GL code = 3 color = dodgerblue
            Error: #<TypeError: reference to deleted Group>
            c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:108:in entities' c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:108:in grouponent_definition'
            c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:182:in grouponent_entities' c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:1440:in edgemap_edges_from_id'
            c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:1959:in block in selection_restore' c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:1947:in each'
            c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:1947:in selection_restore' c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:4809:in geometry_aborted'
            c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:4826:in geometry_rollback' c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:2525:in undo_perform'
            c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:2478:in block in handle_undo' problem with draw GL code = 3 color = dodgerblue problem with draw GL code = 3 color = dodgerblue Error: #<TypeError: reference to deleted Group> c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:108:in entities'
            c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:108:in grouponent_definition' c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:1055:in grouponent_tr_top_all'
            c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:3850:in drawing_hover_edges' c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:3299:in draw'
            c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:1055:in grouponent_tr_top_all' c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:3850:in drawing_hover_edges'
            c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:3299:in draw' Error: #<TypeError: reference to deleted Group> c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:108:in entities'
            c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:3299:in `draw'
            • fredo6F
              fredo6
              Does it happen on any kind of geometry?
              When did the problem appear?
              • kenK
                ken
                I haven't used this plugin for some time, maybe 2 to 3 updates. I was just trying out plugins after installing ver 2021.
                Yes about other geometry, I tried it out on a circular solid.
                  Did you copy the extension from an older version or did you install fresh from here? Both Round Corner and FredoCorner work fine for me in SU2021.
                  • jujuJ
                    juju
                    This is a little off topic, but which of the two is the most recent extension? I keep on forgetting, and checking update dates doesn't help as I think they both get updated currently.
                      FredoCorner is the newer one but it's a good idea to keep both of them. There are some cases where FredoCorner has difficulty and Round Corner doesn't.
                      • kenK
                        ken
                        Fredo6
                        Found the problem. I did the update listed for today. Still problems, no cure. One thing I have learned, if your the only one having the problem, you may be the problem.
                        So I kept looking at what am I was doing wrong. Then I see the problem, I had the #seq set to zero. Will, after changing the setting to ten, presto working again.
                        Sorry to have bothered you. Your programs and your response is always fast.
                        Just a thought, not a programmer, but maybe an error message, "SET THE DAMN #SEQ TO GREATER THAN ZERO, DUMMY"
                        Also, Dave thanks for your help. I did go back and install, then remove and install again, until I was satisfied, that wasn't the problem.
                        Now back to work.
                        • fredo6F
                          fredo6
                          Strange that I left this possibility after so long. Anyway, thanks to remind me.
                          I fixed it in FredoCorner v2.1b, just published.
                          • kenK
                            ken
                            Entirely my pleasure.
