    Texture looks darker and more saturated
    renderpluginsextensions
    5 Posts 2 Posters 6.1k Views 2 Watching
    • G Offline
      gianfranco_bm
      Hi, I've been having the same problem on different files. When I render, I notice that some wood textures come out darker and more saturated than what I'm expecting. The material shown on the Vray asset editor matches the material I see when working on sketchup, but doesn't match the render output. I know it's just colors, but I haven't notice it on other materials. On the image I attach you can see both the floor and the table showing this problem.
      I'd appreciate any help, thx!
      Sketchup Pro 2019 V19.0.685
      Vray 4.00.01
      • N Offline
        nlipovac
        Vray 4.00.01
        • do you maybe have added some layers on your vray mat, like a reflective coat?
        • Maybe you could share vrmat or just the setup of your material?
        • G Offline
          gianfranco_bm
          Vray 4.00.01
          It's a simple .jpg file with no added layers. Vrmat files can't be attached. I'm attaching the screen capture of the material.
          • G Offline
            gianfranco_bm
            When I explode components, and reverse their faces, the interior face supposedly is the default material but it shows black and I know it is related to the color problem. Only when I turned every face to default and applied a new material, it rendered correctly. But I can't do this for every component. I tried to apply the Vray Glass Cristal material to a wine glass component and I had the same problem.
            After playing a bit with the cushion from the image attached, and deleting one of its faces, I saw it was still appearing in the render. Even after I deleted the whole cushion, it still appeared in the render! I purged the file and this stopped, but the problem with the color continued. I'm not sure if it's related, but I think it is.
            Help!
            Meanwhile I think I'll reinstall sketchup
            • N Offline
              nlipovac
              Help!
              Hi, sorry for the late answer.
              You can not run from a problem with SU if you on purpose or accidentally apply a material to a group or component, it messes up your default material and produces problems as you have described.
              I really do not think you will get rid of that problem by reinstalling SU.
              What I do is if I get to that problems I explode a component or a group and apply default material and reapply new material and then make a group or a component again.
              I am almost sure that there is a plugin for that but since I do not get into those problems often I never investigate options like plugins for resolving them. Also, you need to follow advice for all non-single polygon object, ex. like curtains, keep a good orientation of your default material when you are creating a model.
