    Converting a 3D surface (stl mesh) into a 3D SketchUp object
    2 Posts 2 Posters 1.4k Views 2 Watching
    • M
      mbernard
      Good morning all,
      I have an STL file that represents a 3D surface (without thickness). It is a mesh based on triangles (Over 600,000).
      This surface should have a flat base of a certain thickness with opaque faces on the sides in order to present the appearance of a solid object without hole.
      I want to be able to use this surface in SketchUp 2019 software to apply a wood texture.
      Please tell me the different operations to be performed to achieve this result.
      Regards,
      Marc
        Plugin Import Export STL by Didier Bur! πŸ˜‰
