    Set .skp default application?
    5 Posts 5 Posters 2.8k Views 5 Watching
    • C
      CalypsoArt
      I have both 2019 and 2020 0n my machine. However, double-clicking on a .skp file tries to open it in 2019. I tried setting to 202 through the properties but no go. What is the correct way to set 2020 as the .skp default application?
      • BoxB
        Run the 2020 installer using right click Run as Admin/ repair.
        • jujuJ
          juju
          This is current bug with SU2020. Reinstalling / repair installs won't work.
          As a workaround, don't use double click on a file to open a SKP file, open it from within SketchUp2020.
          • sketch3d.deS
            sketch3d.de
            the registry file in the attached ZIP archive should fix this, save the REG file to e.g. the Windows desktop and launch.
            Prerequisite: SketchUp Pro 2020 program installation in default program directory:
            C;\Program Files\SketchUp\SketchUp 2020\
            If using another program directory you can edit the path by opening the REG file with a text editor (not text processor) as e.g the Windows editor and change accordingly.
            Open with SKP2020.reg.zip
            • studio43S
              studio43
              perfect thanks for this
