    Timber brackets for access walkway
    13 Posts 4 Posters 3.2k Views 4 Watching
    • chrisglasierC
      chrisglasier
      Dave R or anyone, if you happen to have a model of a bracket to support this walkway, my residents' committee would be most grateful. It is to access a water tank room, but also serves as a framework for Wisteria or somesuch climber. It is 800mm deep. It needs only to take the weight of a single gardener pruning the Triffid.
      With TBA interfaces we can analyse what is to be achieved so that IT can help with automation to achieve it.
        I don't have anything on hand but if you were to show images of the sort of thing you're after I expect they'd be easy enough to model.
        Out of curiosity,why did you put this in the SketchUp Bugs category?
        • chrisglasierC
          chrisglasier
          Old age and late nights. Will send some ideas this weekend; thanks for the offer.
          • chrisglasierC
            chrisglasier
            Something simple like these but a little less chunky if possible. I know you know about sizes!
            Please move the post to proper place if possible.
            Cheers
            Chris
              I moved your thread for you.
              Here are a couple of ideas before my coffee kicked in. The one on the right has a slight curve similar to the ones in your photo. Keep in mind I am NOT a structural engineer. You should consult with one regarding the design and construction of something like these. As drawn, the one on the left uses 2x6 and 2x4 lumber and the other two are 2x6 and 4x4. The back pieces are 1 meter long and the angled pieces are at 30° from vertical. My guess is that the scantlings should be heavier and/or you will need more of them.
              • chrisglasierC
                chrisglasier
                @dave r said:
                .... My guess is that the scantlings should be heavier and/or you will need more of them.
                I think we will use Sri Lankan teak; so generally, like doors and windows here, section sizes are real slim. The one on the left rather picks up on that. I will model it and see what the locals think.
                If there is a structural engineer reading this, would be most grateful for informal advice.
                And thanks again Dave; always good to prey on your kindness!
                Chris
                • chrisglasierC
                  chrisglasier
                    Looks good.
                    • bazB
                      baz
                      My two bobs worth: I would bring the brackets by the double opening as close together as possible, the span at present seems too wide. And possibly add another.
                      I would beef up the right angle corners of the brackets as well, there will be a large amount of lateral force on that joint.
                      The access stairs worry me, are they removable? I wouldn't like to see a party up there 😞
                      • chrisglasierC
                        chrisglasier
                        Thanks, I am just providing the concept and major components; another guy is creating the model from the cad drawings. An engineer will be involved. But your comments are noted as they say around these parts.
                        Noted.
                        They are just for maintenance staff and Triffid pruner. It will have a hatch at the top. It is next to a small pool, so it is also a kind of drinks stand, clothes horse, poolside thing.Thinks, maybe extend some treads though the vertical trellis.
                        • chrisglasierC
                          chrisglasier
                          Roof walkway.pngWith people, water tank and Triffid
                          • A
                            aikibrown
                            @chrisglasier said:
                            [attachment=0:2r5h93b1]<!-- ia0 -->Roof walkway.png<!-- ia0 -->[/attachment:2r5h93b1]With people, water tank and Triffid
                            If it were my public liability insurance policy on the line, I would be suggesting a steel deck, stairs and railing construction supported on steel SHS posts with suitably designed pad foundations. But then I am based in the UK, where Building Regulations have become more onerous.
                            • chrisglasierC
                              chrisglasier
                              @aikibrown said:
                              ...Building Regulations have become more onerous.
                              Ah yes I remember them ... But here in Sri Lanka we can trip the light fantastic with homegrown teak and a wish and a prayer. Public liability insurance ... what ho!
