    Field of view changed.
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    1 Posts 1 Posters 8.7k Views 1 Watching
    • D
      danirm
      Hi guys,
      thank you in advance for your time.
      As you can see on the attached images (1,2,3), I have setted an animation with Animator on Sketchup,
      the problem comes when I launch the render calculation because it change the field of view by itself.
      Can someone help me with this?
      Maybe you have some more knowledge than me about setting the computer, so I ask you also if you know if it is normal that reading the program requier to use 😧 memory, because it is causing a lot of troubles. (image 4)
      The file weight is 400 mb, so it is not so light, but I can't neither launch the renders since it take 20 minutes before to start the renders.
      I know that is the Animator blog, so if you have some link that can help me to solve this I'd glad to consult it.
      Thank you to all.
      danirm
      Before to open Animator.
      With Animator open.
      After launching render.
