π Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
Unwanted hidden geometry showing in Layout
Trying to get my first drawings output to Layout. When I insert a Sketchup scene into Layout, the hidden geometry of the scene is showing. I cannot find a way to tun it off. Not sure if my trouble is in the Sketchup scene or the Layout settings. Thank you.
Can you share the LO file so we can see how you've got things set up? I expect there's an easy fix but seeing the file will help.
Just a thought. Have you checked your SU scene style settings have hidden lines switched off.
