    Harley Panhead Custom Bobber
    11 Posts 6 Posters 2.9k Views 6 Watching
    • JMJOhioJ Offline
      JMJOhio
      Bobber (motorcycle)
      From Wikipedia
      A bobber, originally called a 'bob-job' from the 1930's through 1990's, is a style of custom motorcycle. The typical construction includes stripping excess bodywork from a motorcycle, removing the front fender and shortening the rear fender, which is "bobbed" (as in bob-tail), and all superfluous parts removed to reduce weight.
      My Version
      • 1949 Hardtail frame
      • 1959 FLH Panhead motor and transmission
      • 1961 Fuel tanks and dashboard
      • Early model 45 springer front end (narrowed and shortened)
      • Custom fenders, saddle and exhaust
      • Standard size Harley FL rear rim and tire (5.00x16)
      • Harley Sportster size front rim and tire (4.00x18)
      Stock 1949 Harley Davidson (photo)
      JMJ Bobber
      First quick render
      • tuna1957T Offline
        tuna1957
        Great ! πŸ‘
          Just about perfect, out of the park. πŸ‘Š πŸ‘
          • JMJOhioJ Offline
            JMJOhio
            Thanks Charles... πŸ˜„
            Thanks Mike... πŸ‘
            • Bryan KB Offline
              Wow! Excellent. πŸ‘
              • JMJOhioJ Offline
                JMJOhio
                Thanks Bryan... πŸ‘
                Some update and new renders. Replaced the gas tank mounted hardware emblem with a painted Harley logo.
                Air cleaner removed showing stock Linkert carburetor.Harley Panhead-9R-2S.jpg
                Primary cover and battery cover removed. Hand shift lever is to left of the saddle. Left foot lever actuates the clutch.Harley Panhead-10R-2S.jpg
                • Bryan KB Offline
                  Top notch work. πŸ‘
                  • ntxdaveN Offline
                    ntxdave
                    Once again some excellent work! πŸ€“
                    Press F1...thank me later
                    • JMJOhioJ Offline
                      JMJOhio
                      Thanks Bryan and Dave... πŸ‘
                      • G Offline
                        garystan
                        JmJOhio :
                        Dang..........you're REALLY good ! And all the detailing DOES impress !
                        garystan
                        • JMJOhioJ Offline
                          JMJOhio
                          Thanks garystan... πŸ‘
