    Houseboat Amsterdam
    27 Posts 8 Posters 5.9k Views 8 Watching
    • jo-keJ
      jo-ke
      Again I've found a nice flormap at archello. this time of a houseboat in Amsterdam and started to build it as a model and put in some furniture.
      Rendered with twilightrender2pro
      pano's are still rendering, (will take a time.....)
      http://www.zz7.de
      • tuna1957T
        tuna1957
        Great job ๐Ÿ‘
        • pbacotP
          Very nice!
          Reminds me of the location in the show "Baptiste". This one has a patio though.
          I wonder if there'd likely be a transition to a different (darker) material near the water line or even some overhang, so that the accumulation of sludge is hidden or managed separate from the siding.
            A nice design there. Not, in my humble opinion a house boat per se more a house barge but I can definitely see where you are going with it.
            • Bryan KB
              Wow! I would love to live there.
              • jo-keJ
                jo-ke
                and some more, while waiting for the panos:
                http://www.zz7.de
                • jo-keJ
                  jo-ke
                  and here are the panos:
                  https://roundme.com/tour/587625/view/1888845/
                  http://www.zz7.de
                    Very cool Pano presentation! ๐Ÿ˜Ž
                    Do you think we can make the same with the free version of "Round me" ?
                    • Bryan KB
                      Wow. Top notch as always.
                      • jo-keJ
                        jo-ke
                        thank you
                        I am using the free version of roundme. so.... yes you can.
                        http://www.zz7.de
                        • jo-keJ
                          jo-ke
                          I think projects. I have never reached the limit.
                          My renderengine isn't fast enough ๐Ÿ˜‰
                          http://www.zz7.de
                            I am using the free version of Roundme so.... yes you can.
                            So amazing! ๐Ÿ˜Ž ๐Ÿ‘ ๐Ÿ˜ฎ
                            And if good understand you can send 15 projects by week with the free one ?
                            (or it's 15 scenes of a same project ? )
                              What (free) Su plugin(s) do you use for create your 360ยฐ Pano Images ? (6 images ? )
                              Cubic Pano by Rami_lpm ?
                              • jo-keJ
                                jo-ke
                                most renderengines have the funktion to render a spherical 360ยฐ Pano. In my case I have used twilightrender.
                                It renders an equirectangular pano. Usually I am using 6000 x 3000 resolution. this works well for a fine quality.
                                This pano is uploaed to roundme.
                                Twilightrender costs around 100 Euro, as far as I remember.
                                But you can use kerkythea for free or twinmotion realtime render for free at the moment.
                                http://www.zz7.de
                                • D
                                  db11
                                  I'm also curious about the panos...
                                  How long do the Twilight renders take on your side (and what hardware are you rendering with),
                                  and how long does the pano take to generate after you've uploaded to Roundme?
                                  Nice work, by the way. Always enjoy seeing your creative output.
                                    Ah ok you must render first ๐Ÿ˜„ free TwinMotion 2019, 2020 perfect...to the life! (not just for the moment! ๐Ÿ˜‰
                                    So here maybe an another solution (but to verify) not sure that was in the freeedition!
                                    but i suppose yes when i read that! (maxi 19200 * 1080)
                                    Supports VR Basic
                                    You can export any scene to VR (Desktop, HTC vive, Oculus) for immersive walkthroughs or product showcases.
                                    (Export basic 3D model, determine start position, navigate using Desktop and VR Viewers)
                                    Simlab composer lite!
                                    • jo-keJ
                                      jo-ke
                                      [quote="db11"]
                                      How long do the Twilight renders take /quote]
                                      too long. ๐Ÿ˜‰
                                      I am rendering with preset #9 minimum 3 passes, better 6 passes. Usually I let it cook over night for perfect output. little denoise and correction in photoshop.
                                      Twinmotion is much faster but quality isn`t as good as twilghtrender
                                      http://www.zz7.de
                                        What is your size output image rendered ?
                                        • jo-keJ
                                          jo-ke
                                          6000 x 3000 works well for me
                                          http://www.zz7.de
                                            So maybe not compatible with the max 1920*1080 of the free version of Simlab composer Lite! ๐Ÿ˜„
                                            • 1 / 2
