    Houseboat Amsterdam
    27 Posts 8 Posters 5.3k Views 8 Watching
    • pbacotP Offline
      Very nice!
      Reminds me of the location in the show "Baptiste". This one has a patio though.
      I wonder if there'd likely be a transition to a different (darker) material near the water line or even some overhang, so that the accumulation of sludge is hidden or managed separate from the siding.
        A nice design there. Not, in my humble opinion a house boat per se more a house barge but I can definitely see where you are going with it.
        • Bryan KB Offline
          Wow! I would love to live there.
          • jo-keJ Offline
            jo-ke
            and some more, while waiting for the panos:
            http://www.zz7.de
            • jo-keJ Offline
              jo-ke
              and here are the panos:
              https://roundme.com/tour/587625/view/1888845/
              http://www.zz7.de
                Very cool Pano presentation! ๐Ÿ˜Ž
                Do you think we can make the same with the free version of "Round me" ?
                • Bryan KB Offline
                  Wow. Top notch as always.
                  • jo-keJ Offline
                    jo-ke
                    thank you
                    I am using the free version of roundme. so.... yes you can.
                    http://www.zz7.de
                    • jo-keJ Offline
                      jo-ke
                      I think projects. I have never reached the limit.
                      My renderengine isn't fast enough ๐Ÿ˜‰
                      http://www.zz7.de
                        I am using the free version of Roundme so.... yes you can.
                        So amazing! ๐Ÿ˜Ž ๐Ÿ‘ ๐Ÿ˜ฎ
                        And if good understand you can send 15 projects by week with the free one ?
                        (or it's 15 scenes of a same project ? )
                          What (free) Su plugin(s) do you use for create your 360ยฐ Pano Images ? (6 images ? )
                          Cubic Pano by Rami_lpm ?
                          • jo-keJ Offline
                            jo-ke
                            most renderengines have the funktion to render a spherical 360ยฐ Pano. In my case I have used twilightrender.
                            It renders an equirectangular pano. Usually I am using 6000 x 3000 resolution. this works well for a fine quality.
                            This pano is uploaed to roundme.
                            Twilightrender costs around 100 Euro, as far as I remember.
                            But you can use kerkythea for free or twinmotion realtime render for free at the moment.
                            http://www.zz7.de
                              db11
                              I'm also curious about the panos...
                              How long do the Twilight renders take on your side (and what hardware are you rendering with),
                              and how long does the pano take to generate after you've uploaded to Roundme?
                              Nice work, by the way. Always enjoy seeing your creative output.
                                Ah ok you must render first ๐Ÿ˜„ free TwinMotion 2019, 2020 perfect...to the life! (not just for the moment! ๐Ÿ˜‰
                                So here maybe an another solution (but to verify) not sure that was in the freeedition!
                                but i suppose yes when i read that! (maxi 19200 * 1080)
                                Supports VR Basic
                                You can export any scene to VR (Desktop, HTC vive, Oculus) for immersive walkthroughs or product showcases.
                                (Export basic 3D model, determine start position, navigate using Desktop and VR Viewers)
                                Simlab composer lite!
                                • jo-keJ Offline
                                  jo-ke
                                  [quote="db11"]
                                  How long do the Twilight renders take /quote]
                                  too long. ๐Ÿ˜‰
                                  I am rendering with preset #9 minimum 3 passes, better 6 passes. Usually I let it cook over night for perfect output. little denoise and correction in photoshop.
                                  Twinmotion is much faster but quality isn`t as good as twilghtrender
                                  http://www.zz7.de
                                    What is your size output image rendered ?
                                    • jo-keJ Offline
                                      jo-ke
                                      6000 x 3000 works well for me
                                      http://www.zz7.de
                                        So maybe not compatible with the max 1920*1080 of the free version of Simlab composer Lite! ๐Ÿ˜„
                                        • jo-keJ Offline
                                          jo-ke
                                          pano has always bto be 2:1 for example 6000 x 3000 in your case 1920 x 960
                                          but the resolution is to low, it wouldn't look nice
                                          http://www.zz7.de
                                            measuredmove
                                            Always look forward to your posts of new designs and panoramas. I have 2 questions:
                                            Do you use FOV in a small tight space to create pano or is it too distorting?
                                            Do you occasionally have trouble accessing/uploading RoundMe? I was able to upload 6 panos for a tour last night but today I can't access the site, as well as someone I shared the link with-there is a warning that the site is not secure. Trying to access your pano, today, had the same warning
                                            My 3D Catalogue
                                            https://3dwarehouse.sketchup.com/collection/103ed44c-a0c4-4049-9a84-89cd017bcc07/Measured-Move
                                            SU8/Brighter3D/Gimp/SimLab Composer
