    Houseboat Amsterdam
    27 Posts 8 Posters 4.5k Views 8 Watching
    • Bryan KB Offline
      Wow. Top notch as always.
      • jo-keJ Offline
        jo-ke
        thank you
        @pilou said:
        Very cool Pano presentation! ๐Ÿ˜Ž
        Do you think we can make the same with the free version of "Round me" ?
        I am using the free version of roundme. so.... yes you can.
        http://www.zz7.de
        • jo-keJ Offline
          jo-ke
          I think projects. I have never reached the limit.
          My renderengine isn't fast enough ๐Ÿ˜‰
          http://www.zz7.de
            I am using the free version of Roundme so.... yes you can.
            So amazing! ๐Ÿ˜Ž ๐Ÿ‘ ๐Ÿ˜ฎ
            And if good understand you can send 15 projects by week with the free one ?
            (or it's 15 scenes of a same project ? )
              What (free) Su plugin(s) do you use for create your 360ยฐ Pano Images ? (6 images ? )
              Cubic Pano by Rami_lpm ?
              • jo-keJ Offline
                jo-ke
                most renderengines have the funktion to render a spherical 360ยฐ Pano. In my case I have used twilightrender.
                It renders an equirectangular pano. Usually I am using 6000 x 3000 resolution. this works well for a fine quality.
                This pano is uploaed to roundme.
                Twilightrender costs around 100 Euro, as far as I remember.
                But you can use kerkythea for free or twinmotion realtime render for free at the moment.
                http://www.zz7.de
                  db11
                  I'm also curious about the panos...
                  How long do the Twilight renders take on your side (and what hardware are you rendering with),
                  and how long does the pano take to generate after you've uploaded to Roundme?
                  Nice work, by the way. Always enjoy seeing your creative output.
                    Ah ok you must render first ๐Ÿ˜„ free TwinMotion 2019, 2020 perfect...to the life! (not just for the moment! ๐Ÿ˜‰
                    So here maybe an another solution (but to verify) not sure that was in the freeedition!
                    but i suppose yes when i read that! (maxi 19200 * 1080)
                    Supports VR Basic
                    You can export any scene to VR (Desktop, HTC vive, Oculus) for immersive walkthroughs or product showcases.
                    (Export basic 3D model, determine start position, navigate using Desktop and VR Viewers)
                    Simlab composer lite!
                    • jo-keJ Offline
                      jo-ke
                      [quote="db11"]
                      How long do the Twilight renders take /quote]
                      too long. ๐Ÿ˜‰
                      I am rendering with preset #9 minimum 3 passes, better 6 passes. Usually I let it cook over night for perfect output. little denoise and correction in photoshop.
                      Twinmotion is much faster but quality isn`t as good as twilghtrender
                      http://www.zz7.de
                        What is your size output image rendered ?
                        • jo-keJ Offline
                          jo-ke
                          6000 x 3000 works well for me
                          http://www.zz7.de
                            So maybe not compatible with the max 1920*1080 of the free version of Simlab composer Lite! ๐Ÿ˜„
                            • jo-keJ Offline
                              jo-ke
                              pano has always bto be 2:1 for example 6000 x 3000 in your case 1920 x 960
                              but the resolution is to low, it wouldn't look nice
                              http://www.zz7.de
                                measuredmove
                                Always look forward to your posts of new designs and panoramas. I have 2 questions:
                                Do you use FOV in a small tight space to create pano or is it too distorting?
                                Do you occasionally have trouble accessing/uploading RoundMe? I was able to upload 6 panos for a tour last night but today I can't access the site, as well as someone I shared the link with-there is a warning that the site is not secure. Trying to access your pano, today, had the same warning
                                My 3D Catalogue
                                https://3dwarehouse.sketchup.com/collection/103ed44c-a0c4-4049-9a84-89cd017bcc07/Measured-Move
                                SU8/Brighter3D/Gimp/SimLab Composer
                                  Maybe site is not working the week-end ?
                                  • jo-keJ Offline
                                    jo-ke
                                    yes round me ist often down. uploading ist always a pain.
                                    http://www.zz7.de
                                      measuredmove
                                      Thanks for letting me know. I thought it was me messing it up.
                                      My 3D Catalogue
                                      • pbacotP Offline
                                        I gave up on Roundme perhaps too soon. Log on problems seemed unsolvable. I have used Momento 360 but it has fewer features.
                                          measuredmove
                                          Kuula https://kuula.co/about is a really nice program too that I use in a pinch. The free version allows you to upload multiple files but you can't link them in an interactive tour like Jo_ke's amazing presentations. The Pro version is subscription and seems to have a lot of bells and whistles. I've seen it used by realtors for house tours. It has those circle Hotspots on the floor to move from room to room.
                                          My 3D Catalogue
