    The 10 plugins you install first ?
    6 Posts 6 Posters 1.9k Views 6 Watching
    • xtovX Offline
      xtov
      Time to switch to Sketechup 2020.
      I am curious:
      What are first the 10 plugins (among many others) you will install ?
      For me (architect), it should be:
      1. JHS Powebar (this one is cheaty, a bunch of very useful plugins)
      2. IntrepidBear Vistool
      3. Mirror
      4. Selection Toys
      5. Material Replacer
      6. Bezier
      7. Joint Push Pull
      8. Curviloft
      9. FredoTools (Ah ThruPaint !) (and FredoScale)
      10. Round Corner
      (and before Sketchucation plugin, obvisously ,))
      Stay safe.
        For the fun ☀
        in any order and free
        1. Soap Skin Bubble by Josef Leibinger
        2. Extrude Tools by Tig
        3. Joint PushPull Interactive by Fredo
        4. Flowyfy by Caul
        5. Subdivision Loop By Guitar List
        6. VisuHole by Fredo
        7. PBR (for cool speed render ) by Samuel
        8. Deck Maker by Sdmitch
        9. Lattice Maker by Tig
        10. Random Component Replacement by SdMitch
        And an extra one who is not inside SketchUp but for Sketchup(& others) : the free Twinmotion! ☀
        Have fun Modeling! 😎
          db11
          1. Cadalog Edit-in-Place
          2. BackOut
          3. Throw_To
          4. Selection Toys
          5. CleanUp3
          6. CenterPointAll
          7. TIG-weld
          8. FredoScale
          9. Eneroth Lift Entities
          10. Eneroth Solid Tools
          11. FredoCorner / RoundCorner
          12. ProfileBuilder 3
          There are another dozen plugins that I always have loaded — plus Sketchucation (of course!) and 3DXSketchUp (for my SpaceMouse) — but these are the ones I use (almost) every session.
          • PixeroP Offline
            Pixero
            It's hard to pick just ten but these are some of my most frequently used ones so they are most likely to be the first ones installed.
            Here is my list:
            1. Sketchucation - The best way to manage plugins in SketchUp.
            2. Scrtool - An oldie to left click reverse faces.
            3. ene_texturepositioning - How did I managed before it existed? One of, if not THE, best plugin IMHO.
            4. weld_mod - my modified version of the weld script without any popup menus.
            5. Mirror - This is one of the scripts I feel should be native to SketchUp.
            6. BackOut - Close nested groups/components in one go.
            7. toComp - My own script to create components without the popup menu.
            8. 3pt_Window - My own script to create good enough windows fast.
            9. EdgeExtruder - My own script to pushpull edges.
            10. Chaos - My own script to randomly move, rotate and scale stuff.
            • K Offline
              kaas
              without a specific order - all installed in one go - can't work without any of them;
              mirror
              fredoscale
              fredocorner
              archiver
              selection toys
              cleanup
              profile builder
              ene-texture positioning
              solid inspector
              split to plane
              and a few of my own plugins
                JackKitch
                1. cmd_auto_invisible_layer - When adding a new layer you it doesn't make it visible in every scene.
                2. ene_texturepositioning - Quickly change texture orientation with Shortcut
                3. Mirror - Self explanatory
                4. PutOnLayer_sortname - Easily cleanup someones messy layering in a model
                5. SectionCutFace - To create sections that you can then draw on
                6. tt_selection_toys - Select only face/edges/hidden lines etc...
                7. su_solarnorth - Change north position
                8. RoundCorner - Self explanatory
                9. TIG-weld - Weld edges together into single edges
                10. SU Podium Browser - For models / materials etc...
                11. 1001bit_freeware - I only really use the fillet tool on this. But it's really useful.
